Question about Microsoft Flight Simulator X for Windows
System ''Lock up" when running FSX Pro
My operating system is Windows XP. The problem I am having is: having loaded flight simulator and it seems to be working fine, until I need to ''minimise'' & ''maximise'' the window. Normally I carry out this function by selecting,' views' & 'minimise' or 'alt + 'enter'. At this point the window locks up, forcing me to go to: ctrl + alt+delete.
I have tried everything!! Can you please help?
Robert
  • Anonymous Mar 28, 2014
    it was working normal, but at some time ago i can`t open the game I meen signe FLIGHT SIMULATOR X appears but game no run anymore even after several times getting out and on from PC
    Problem Solver:
  • 6 Answers
You can try alt + tab. or do alt + ctrl + del win the game DOES run fine. windows task manager will pop up and it will push flight simulator in the taskbar.
if it still crash, check your patch on the game. maybe it has a "minimise-lock". which means: it cant minimise cause the producer doesnt want too (but i cant see why he care ^^)
hope i helped you
kilbeam99
PS. just curious: why do you want to minimise?
Posted on Jan 15, 2009
Loaded but wont run when activated
Check this link for more info...
Also don't know your OS ?
Flight Simulator 2004 doesn't run correctly on Windows 8. It runs on my Windows 8 laptop bought in April 2013. But, none of the aircraft, including any add-ons, show up in the preview window - it is always black. Also, If I download weather and try to save a flight, when I go back to that "saved" flight, it always reverts to the default flight with the Cessna @ the default airport. If anyone knows how to make the flights save, on the Windows 8 platform, please let me know - likewise, with the aircraft previews. Flight Simulator 2004 did quite well on the Windows XP platform for me.
Apr 18, 2014 | Microsoft Flight Simulator 2004 Update
I have 64 bit system. is ms flight simulator 2002 compatible with that?
MS Flight Simulator 2002 should be compatible with your 64 bit operating system.
It should, SHOULD, normally install.
If you have troubles running the program, I suggest right clicking on the shortcut and run it in XP SP2 compatibility mode. But, you shouldn't have to do that.
Mar 12, 2011 | Microsoft Flight Simulator 2002 Standard...
The software I am using is Microsoft Flight Simulator X. The machine I am using is a Dell Inspiron 4700 with upgraded video using a Radeon HD 5450. The problen arrises only when I enter into my Flight...
Hi paperchap
You didn't mention in your post what problem you're having.If you can post that it will help.
In the meantime,I looked into your card for some general information.It's not really designed as a gaming card,but FSX isn't that graphics intense either.
When you installed the card did you install drivers from the disk or did Windows recognize the card and use it's own drivers?
Either way I'll give you a link to the newest XP drivers from Radeon.You should download and install the driver,the catalyst control software is optional.
Let me know what the problem is,and if you download the drivers and that fixes it would you please rate my post?
Post back,I'll help out with what I can.I run FSX quite a bit.
Bob
Aug 18, 2010 | Microsoft Windows XP Home Edition
Bought the saitek headset how do configure to talk to the tower in the fsx game
You cannot talk to the tower in FSX, only via third part software and then the button you wish to use would be configured within that software (such as Live ATC),
May 15, 2010 | Saitek Pro Flight Yoke System Flight...
I have Microsoft Flight Simulator X and a Satek X52 flight control, however I have problems with the throttle on all aircraft. I have to use the F-4 key - can you help?
You need to assign the throttle function correctly WITHIN FSX settings area itself. Also calibrate the joystick in windows first. If you are not familiar with assigning FSX functions to your joystick, check the Learning Center section within FSX for step-by-step details.
Feb 24, 2010 | Microsoft Flight Simulator X for Windows
On saitek yoke system it wont work on fsx *flight simulator x* if you can help thanks !!!!!!!!!!!!!!!!!!!!!!!
Ensure you have installed the drivers for it. If you don't have them, go to Saitek web site, download and install the correct one's for your operating system. Also ensure that the yoke is plugged into the USB port on the rear of the PC as these USB sockets give the most power. Additionally, you have to set the yoke up in FSX\Settings so it knows what to do with it with regard to calibrating it and assigning what buttons do what.
Sep 07, 2009 | Saitek Pro Flight Yoke System Flight...
Hi, I contacted Saitek approximately 2weeks ago regarding the blueand purple backlight failure on my Eclipse II keyboard. I am awaiting your reply. I now have, what I feel to be a more serious failure on...
Hi Chris
Ensure that you have the usb lead from the yoke plugged into the rear of the PC as these give the most current. Ensure the drivers for the yoke are installed properly and they are the latest for your operating system. If this still does not work, then the yoke is faulty. Good luck!
Jul 23, 2009 | Saitek Pro Flight Yoke System Flight...
FSX Free Flight shuts off
I had this Problem It seemed to fix it when I ran the game in Compatibility with Windows Xp SP2 and Ran as administrator
To do this Right Click the Icon
Got o Properties
go to Compatibility tab
Click the Box That says "run this program in Compatibility mode for:"
and Windows Xp Sp2, Should be automatically selected
And at the Bottom Under "Privilege Level"
click Run as an Admin
Jun 02, 2009 | Microsoft Flight Simulator X for Windows
MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Nov 23, 2008 | Saitek Pro Flight Yoke System Flight...
Microsoft Flight Simulator X for Windows Logo
607 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
