Question about Microwave Ovens
NEED TO KNOW SIZE OF SURFACE LIGHT BULBS.
WHAT IS THE SIZE OF THE BULB IN MY GE PROFILE MICRO OVEN
SURFACE LIGHTS XL1400. ?
JOHNROSS1@EARTHLINK.NET
Went to the store a got a new one
Posted on Jan 18, 2009
Changed the light bulbs in my ge jvm315 and know the surface light will not turn off ?
This sounds like the control board also called a smart board in some models has to be replaced.
May 02, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Why would my microwave no longer heat or cook?
micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Burned out bulb on GE spacemaker micro
This is pretty common and can be a pain. It's tacked in place with contact cement or hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
You should check your light sockets for a short, to, before you put in new bulbs.
Once you have the new bulbs in, the cooktop lights still may not work.
We see (and repair) this a lot. This problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 30, 2009 | GE Profile Spacemaker Over-the-Range...
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
Surface light "nightlight" will not work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Feb 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker microwave surface lights
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Sep 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1460 surface light problem
William E. Miller
prototech@usa.net
Aug 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1400 Microwave - Lights wont cut off
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too, due to a shorted relay.
Aug 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
230 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
