Question about GE WDSR2080D Top Load Washer
Cold water pours in during final spin
I have a Kenmore stacked washer/dryer combo model number 417.98702891 (not sure of the year). When I run it through the regular cycle with the water set to Hot/Cold, it works perfectly. When I run the same cycle on Cold/Cold, it doesn't. It will fill and drain fine and shuts off when it is full.
The problem is that the final part of the cycle, the spin, it will pour water out while spinning thus making the clothes wet when it is done (occasionally the tub will be partially full at the end of the cycle). If I switch the water from Cold/Cold to Hot/Cold during this final spin, the water will turn off and it will function normally. It does this for all cycle settings.
At first I suspected the timer was bad, but I now suspect it is the cold water inlet valve. However, if it is the cold water inlet valve, why would it work fine throughout the cycle except during the final spin?
  • 1,294 Answers
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Posted on Mar 12, 2009
5 Suggested Answers
SOURCE: Water Shut off
It sounds like you need a new control valve. the control valve turns on and off the hot and cold water, its electronically controlled so it could be something else but more than likely its just the valve. I had mine go out about 6 months ago, plug and play i was out $30 but that was it.
Posted on Aug 23, 2008
SOURCE: dryer noise sounds like bearing out or a roller is
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Posted on Feb 23, 2010
  • 15935 Answers
SOURCE: cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
  • 643 Answers
SOURCE: just bought a condo that
No the Kenmore 98702 Stacked Washer / Dryer has only 1 power source just the 220V
Installation manual is located Here
Posted on Jun 25, 2011
My Kenmore Washer Dryer Combo stacked unit Model # 417.92702200 will not drain it has noise and runs thropugh the cycle then spins like it should just will not drain out water after its done wash cycle....
looks to me that you have eather coins, yes,coins traped in the electric water pump mostly a quarter blocking the inlet of pump or a piece or clothing from the hose that comes from the bottom of the OUTER TUB to the PUMP. if not you may have a faulty pump.
good luck to you.
Feb 07, 2011 | Kenmore 22422 Top Load Washer
I can not figure out how to get this machine to dry. I was told it was a combo machine that both washed and dried. Does it really dry and how?
I will be glad to help you. Can you please post the make and model number of your machine so I may provide you the proper information?
Happy Holidays The FixYa Team
Dec 21, 2010 | Washing Machines
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
No rinse
Make sure that you have both, hot and cold water connected and turned on. Some models will not advance through rinse if one of the hot or cold is off. See if this solves the problem, Catriver.
Jul 21, 2006 | Kenmore 80754 Top Load Stacked Washer /...
GE WDSR2080D Top Load Washer Logo
193 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
