Question about Acer Aspire E700 PC Desktop
Picture does not fill Screen
I have an Acer Aspire E700 PC connected to an HP w2216 Monitor.
It's been working okay for some time but suddenly the MS Vista picture moved over to the right leaving an 80 mm. blank gap on the left.
This is now permanent. It cannot be fixed using the Monitor controls or the Software. When the computer is first turned on the whole screen is filled but shrinks as soon as Vista kicks in. Could this be a Display Driver problem? Any help would be appreciated.
  • rcsnet
    rcsnet May 11, 2010
    Video Driver issue, for sure is checkpoint #1. hop over to the Acer website, they SHOULD have a Vista Update.
    Checkpoint #2: see if there's a specific monitor driver at support.hp.com
    Checkpoint #3: see if you can backtrack to when the problem started, you might be able to recover from the date (rollback).
    LEAP OF FAITH: something to sniff out... I don't personally have Vista, BUT see if there's a setting for ASPECT RATIO under Video Properties or somewhere related.
    We'll leave the question open.... someone might find this and know what to do, but these are my learn-ed suggestions. Best of luck!
  • 43 Answers
It is displays fine up unto the point where Vista loads, then it must only happen when Vista loads the display driver. I would go with your initial assumption and reinstall the display driver.
Posted on Jan 15, 2009
My Acer Aspire E700 will not start up. When I press the power button, you can hear it begin to start but then nothing. Almost like a car trying to turn over is the only way to discribe it.
you could have a bad video chip. Failure to POST could mean anything, but most times it's a video chip. Still, you can try re-seating your ram chips, re-seating your CPU, and re-seating the add-on cards that you may have.
Sep 22, 2012 | Acer Aspire E700 PC Desktop
Aspire one black screen problem
Hook a spare monitor to the video output usually on the back, if picture okay! the inverter board just below the laptop screen is defective, "more than likely" or the backlight behind the display is faulty, but if both show the same symptom it is the video graphics card normally built into the motherboard.
Apr 23, 2012 | Acer Aspire One PC Notebook
I changed the power supply on my acer aspire e700 and it beeps continuosly non stop with no picture on screen, the last power supply blew. it had a graphics card when i bought it but it stopped working so...
You may have more problems than just he power supply from when the old power supply went out. The mainboard could be bad.
Make sure it's unplugged from power from the wall, then check that the memory is seated correctly. Check for anything else that may be out of place or not fully connected.
There are also different beep codes for different errors. They've mostly been standardized, but may vary by mainboard as well. Here's a link to common POST beep codes and their meanings:
Computer POST and beep codes
May 19, 2017 | Acer Aspire E700 PC Desktop
I got a friends acer aspire E700 and kids got to
just check with ram if there is 2 diffrent ram just remove one and try for installation.
Jan 25, 2010 | Acer Aspire E700 PC Desktop
My ACER Aspire M5641 suddenly doesn't connect to screen
Look for one of your "F" keys with a picture of a TV on it. Press thie and your "FN" key at the same time. It switches from one output source to another.
Sep 27, 2009 | Acer Aspire M5641 PC Desktop
Hi can u tell me how to get the speakers to work on my HP w2216 monitor please
make sure the speaker cables are connected the cpu and monitor
Aug 03, 2009 | HP L2208W Monitor
''acer aspire one external monitor output splits external screen picture in two'' when i plug my acer aspire one into an external screen it splits the picture on the external screen in to two, its not the...
XP - Simply on a blank part of the screen right click mouse and select properties, you should be in display properties, selections are there and you should get hte picture(s) you want
Apr 17, 2009 | Acer Aspire 3680 Laptop
Acer aspire one will not work.
If you get a post screen with Acer written on it at startup, and the screen turns off when loading the system (Windows or Linux), then you need to reinstall the system using an external USB cd unit and the recovery disk that was provided with your Acer.
If instead the display has no screen at all , try connecting an external monitor to test the laptop.
If you get picture on external monitor, then the Aspire One has a faulty LCD ribbon cable or a faulty LCD display or inverter.
If you get no picture on external screen , then you have a faulty motherboard, possibly faulty video chipset on motherboard.
In any case check your Acer One warranty, all the faults listed are covered by Acer warranty for one year.
Contact Acer at the number listed on documentation to have the computer repaired.
Mar 13, 2009 | Acer Aspire One PC Notebook
Black screen
when problems occures with monitor is always with picture tube but some time less brightness is also reason for black screen
check brightness of your system i think it should be on maximum level and brightness is perfact so i said problem with picture tube. may be picture tube is gone...
Mar 28, 2008 | Acer Aspire 5050-3242 Notebook
New Acer Aspire E700 does not load-up
Does your BIOS POST runs then you might be having a Disk Booting Problem, If you dont see your BIOS POST Screen, then check if you can hear any beep sounds, If you hear beep sounds check the ram whether it is properly inserted in the ram slot or the ram might be faulty.(You may have to change the Ram). If you dont hear any beep, check whether the buzzer(Speaker in the CPU) is working, If buzzers were working fine before, then you might be having problems with your mother board or processor. If you know how to work on such problem try reinstalling the processor, ram etc in the cpu . Otherwise call a service engineer to have the job done.
Jan 01, 2008 | Computers & Internet
Acer Aspire E700  PC Desktop Logo
189 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
