Question about Kenmore 22442 Top Load Washer
To much lint on my clothes after washing
My washer is old and we have very hard water. I have no filter to clean on my washer. I have tried cleaning my washer with a vinegar soak & wash. I've tried soaking & wash cycle with bleach also. Help I want clean clothes at the end of my wash cycle. When I take the clothes out of my washer, what I see is lint everywhere and my dry Costco soap won't dissolve most of the time when I use cold water, but I don't want to use hot water and shrink everything. What else can I try short of buying a new machine that I don't have the money for?
  • Trish Wulbern Jun 16, 2007
    I need all the help I can get
    Sergeant:
  • 236 Answers
Try an emptyhot wash with some limescale remover in approx quater of a litre, let it run all the way through the wash then put on another rinse to clear out system. check the next water fill for any debris/lint left.
Posted on Jun 16, 2007
If possible you might have to take the wash machine apart...first by take the washing machine drum out and clean it ,and also cleaning out the lint trap by the pump inside the machine.Not a easy thing to do...this is the last resort if all things fail...
Posted on Jan 01, 2009
SOURCE:
I wash all my darks together. No fuzzy stuff either with the black items. Don't overload as I am only person doing laundry. Why the lint left on the clothes. Kenmore Elite Series 600. Please help.
Your Kenmore washer does not have a lint filter. Washers manufactured today and in the past few years are not designed with lint filters. The engineers rely on the dryer to remove any lint left on the clothes that doesn't get flushed down the drain.
overload the washer? The wash load must be balanced and not overloaded. Clothes should move freely.
Lint can be trapped in the load if overloaded. Wash smaller loads.
Use the correct water level? The water level should be correct for the load size. Clothes should move freely in the water.
Alsp liquid detergent works better in cold water and has modifiers to keep lint in the water not on the cloths.
Do you line dry your clothing? If so, you can expect some lint on the clothing.
Check the following too
Was paper or tissue left in the pockets?
Use the proper cycle time for the load? Reducing wash time (duration) is another way to reduce lint.
these should help in reducing the amount of lint left on your clothes.
Thank the wonderful engineers for this problem.
There is one other thing you can do. Micro fiber cloths attract lint like nothing else. Inexpensive ones added to a wash load will catch almost all the lint.
found this out the hard way by trying to clean some that I used in auto body seminars for removing polish and waxes when doing detailing demos. they came out full of lint when washed in a mixed load,..looked worse than they did dirty. well sort of..they were still good for what i wanted them to do but looked like heck. :) if rewashed alone they cleaned up.
hope I helped a little.
Dec 31, 2017 | Kenmore Washing Machines
Does this machine have a lint filter? I am getting bits of yuk on my washing after the wash is finished
No lint filter. The tumbling wash action generates very little lint, which washes down the drain.
To get rid of the "yuk":
Open the access panel on the lower left corner on front of the washer.
Use small hose to drain the remaining water from machine.
Remove the pump filter next to the hose, clean it out, and replace it.
Run the washer with a commercial washer cleaner such as Affresh, washer magic, or whirlaway hot tub cleaner, no clothes, hottest longest cycle possible. Use the tub clean cycle if your model has it.
Resume washing, using one tablespoon of HE detergent per cycle. Use only 1 teaspoon of fabric softener if you use that. These machines use much less water than the old top loader ones, and thus you must use much less detergent.
Feb 24, 2011 | LG Washing Machines
I WANT TO CLEAN OUT THE FILTERS BUT CAN'T FIND THEM. tHE WASHING MACHINE IS 3 YEARS OLD AND IS WORKING BUT IS A BIT SMELLY AND CLOTHES ARE NOT AS CLEAN. I USE REAL NAPPIES AND USE THE MACHINE DAILY SO IT'S...
Remove lowwer rrear panel. locate and remove the large black hose fastened to bottom of drum, there should be a plastic filter inside the hose, if not, then filter is located at bottom front right of washer behind cover.
Sep 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
We have a Whirlpool top loading washing machine that leaves the clothes covered with lint after each load. Delicate clothes that have elastic bands are covered with pieces of lint on the bands that are...
Your service man is right, the lint is filtered through the filter plugs on the bottom of the tub, and backflushed out during the spin cycle. This does not do a great job of filtering out the lint that came out of the clothes. So why is there so much lint? Three reasons: 1. Clothes being beaten against the agitator, tub, each other. The Whirlpool washer has a pretty decent way of agitating the clothes without too much damage, as long as there is plenty of water for the clothes to move through. As long as you make sure your load size and water level are correct, this shouldn't cause a lot of lint. I always have a larger water level than the load size calls for. 2. Lower quality material in the clothes. We definitely see this a lot, especially in the cheaper towels, rugs, sweaters, ect. Some of these have such cheaply made fibers, that they put out a lot of lint. 3. Laundry soaps. Most soaps are very caustic detergents and eat the fibers right out of the linens. There are some brands of washers that still use a type of metal in them that this soap eats right up, so in a few years the machine is junk. All of the washer manufacturers went to plastic outer tubs, as the soap was literally eating holes in the outer tubs in 2 to 3 years on some brands. This is one of the reasons we have so much of the micro lint that is so fine, it goes right through your dryer lint filter and causes lint build up in the venting itself. Years ago, at our shop in Hawaii, we tested naturopathic soaps for 12 years before we settled on the Melaleuca brand for our laundry soaps. Ph neutral, cleans the clothes better than any brand we have tested before or since, does not leave the sludge in the outer tub that most brands do, does not leave a hard aggregate in the tubs like some other brands do, is cheap and does not cause the allergys, athsma, skin rashes, ect. that most of the caustic brands are doing. We have used it for over 10 years now and see very little lint in our Whirlpool washer. Look it up online, join it, and buy the soap directly from the company. It sounds like you have done everything else correctly to the washer, that you could have. I am impressed, most people could not have done what you did. Hope this helps. Good Luck, Appliance Specialists
Jan 22, 2010 | Washing Machines
I have a whirlpool top load washing machine model no. 6ALSQ8000JQ2. it is about 7 years old and does not have an area that collects the lint in the machine. Previously this was not a problem, but in the...
You have taken the necessary steps to reduce the lint problem. It seems they have not worked sufficiently. Another lint factor is due to HARD WATER.
You may have to disassemble the washer and remove the inner wash tub. On the bottom of the wash tub is a self cleaning lint filter. It may be gummed up with detergent and lint not allowing it to do its job. It will have to be manually cleaned.
Oct 06, 2009 | Washing Machines
Washer not cleaning clothes
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Try using powders for 'front loaders'
Apr 05, 2009 | Kenmore HE2 Plus Front Load Washer
LINT STICKS TO MY CLOTHES IN WASHER
linting is caused by a few things
firstly what sort of soap poweder do you use
i recomend good quality powder
do not wash clothes too long as what you are doing is rubbing all the fibres out of them
good quality washing powder only last about 6 minets in water and after that it looses its qualiteseg
the PH changes in the water
you may be using too little soap powder and this also depends on water quality eg too hard or soft water
is the water levels set corectly
do not mix washing
eg towels with jeans as the lint will come off onto jeans
try using delicate wash on different fabric as the adgitation is different on different cycles
try using warm wash and not cold machine is probable ok but wah times are important
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
Excessive lint on clothes and smell
There is many solutions that work some. The best analogy I have seen is to reduce the wash time as the newer soaps are more efficient at removing dirt which also softens the fabric. Any excess in soap regardless of type in combination with water type will cause an odor, why is the contaminents in the water plus the junk on are clothes to be polite. It builds up under the basket and along the top water line in the tub plus creates a film from the tub through the hoses, pump and house drain. Lint is a product of excess washing and too much soap. Whirlpool stated for there front loaders no more than two TBL of liquid soap which is like 3/8 cup max for the old top loader. SearsTechToo
Apr 27, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 22442 Top Load Washer Logo
261 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
