Green Line in Philips 42TA648BX/37 42" LCD
A vertical green line appeared on the right side of screen when watching HD channels unscaled on a Comcast DVR with HDMI cable. Switched to componant cables and got a black stripe on the same side. Hooked the cable directly from the wall to the tv and had no issues. Any ideas???
Just a guess. Try to get hold of a different cable box & see if you have the same problem. If so, problem is with cable box.
Posted on Apr 02, 2009
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Vertical green line screen try
Have you tried to do a reset via the monitors menu options?
Jan 21, 2014 | HP w1907 LCD Monitor
A yellow line going down the left side of the television
you likely have the "screen size" option set to allow the TV determine the best size (3:4 , 16:9, ...). Set it manually to 16:9 for HD channels or 3:4 for low-def channels.
The line should go away. This is a common problem on Samsung, Sony (Green line right side) and Phillips (yellow line left side).
May 05, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
Green line on HD channels on the right side of screen
adjust the monitor as all default, if there is a problem i think the problem come from hardware, contact service center to fix it
Dec 03, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Small green line on right side of screen
This is an easy fix using the Philips remote control that came with your tv. On the center of the remote is a dial that has left right up down controls. Stand in front of the tv and using those controls you can recenter the screen and get rid fo the green line. I had same problem when we hooked up hd satellite reciver to philips 37 plasma
Feb 18, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Green line running vertically along the edge of picture
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob or a line. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Jun 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Green line problem
I had the same problem when we hooked up an hd satellite box. It's a simple solution using the Philips remote that came with your tv. The dial in the center of the remote with up down left right control will move the picture left or right up or down by holding the direction you want to go. Make sure to stand in front of tv.
Oct 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green line
sharp is very aware of the panel and main video processor problems.They should give you no problems on the repair.It sounds most likely you have a main video processor problem.
Mar 13, 2008 | Televison & Video
Televison & Video Logo
843 people viewed this question
Top Televison & Video Experts
