Back to:
Tags:
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
HOOVER STEAM VAC SPIN SCRUB
posted by KROCK on Jun 16, 2007
MY HOOVER STEAM VAC SPIN SCRUB DOES NOT SEEM TO HAVE THE SUCTION POWER IT USED TO HAVE. I CANNOT LOCATE THE MANUAL TO SEE HOW TO CHECK FOR OBSTRUCTIONS. ANY IDEAS?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 22, 2007
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Check the flexible hose that comes down from the handle.  Look for a crack where it plugs into the base unit.  (visible once you open the handle up and remove the cleanable catch basket)
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on HOOVER STEAM VAC SPIN SCRUB:
I don't want to Accept this solution
Solution #2
posted on Aug 02, 2008
Not Rated (0)
chrisg_33405
Rating: 0%, 0 votes
Cannot hook the upholstery cleaner into slot..lost manual in fire
Thank You!
Can you Help with these Vacuums problems?
Hoover SteamVac F5914-900 SpinScrub Upright...
The red full indicator under the filter raises to stop the...
Hello, I was wet vacuuming earlier and when I went to...
I used the unit about two weeks ago. I cleaned the unit...
how do i get the apulstry brush to turn and there is no...
Just purchased a Hoover Steam Vac with clean surge. The...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
