Question about Xerox Phaser 8560DN Laser Printer
FAULT 37,016.43:19084 PRINTER WILL NOT WORK
    Novelist:
  • Xerox Expert
  • 297 Answers
This error refers to the head maintenence clutch, but could be just the first error it gets before the real problem.
It could be a broken drum maintenance camshaft or pivot plate.
Also check the Process Drive Gears Assy. that all gears are matched up with the small holes in them.
Posted on Jan 16, 2009
Hammer bank fault in p500b printer
check your fan it is working fine or not otherwise logic card fault detection circuit having problem. low value resistance may open
Feb 28, 2014 | Printronix Office Equipment & Supplies
Cleaning Page
Please, read this maintenance document first and try again.
Dec 02, 2011 | HP LaserJet 1022 Printer
Intermec 4400 printer fault. Ribbon fault. Looking for a service manual for this printer.
Ribbon fault when using Direct Thermal paper?? This one got me, too. Easy to correct, but issue was with driver & software from Intermec! To reset, go to OFFLINE READY, press MENU, Up/Down to OFFLINE CONFIGURATION, press SELECT, Up/Down to LABEL MEDIA TYPE, then SELECT, Up/Down to MEDIA TYPE DIRECT THERMAL, SELECT, ENTER and MENU out. To be sure, cycle power - and it works again.....
Oct 17, 2009 | Intermec EasyCoder 4400 Thermal Printer
Hp 4288 all in in one scaner is not working
Suggest the following
1) if not installed - install service pack 2 for vista - remove and reinstall HP software.
2) remove any software for Kodak digital Cameras (found by Googling and may not work)
3) Contact HP ;-)
Jul 07, 2009 | HP DeskJet F4280 All In One Printer InkJet
Kodak easy share printer dock series 3 faults
got same error, took the clear cover off the paper cartridge and kinda' force fed the paper thru. To my surprise...it worked.
Jul 02, 2009 | Kodak Office Equipment & Supplies
Fault message comes up after the printer is powered on
That is a print head fault. Most likely the print head itself has failed.
Mar 11, 2009 | Xerox Phaser 8550DX Laser Printer
Printer not working
That is a drum warm up fault. There are 2, 150 watt halogen lamps in the drum heater that blow.
If you want to replace them let me know, I will sent you the directions. I can pretty much say 100 percent that is the problem.
Feb 16, 2009 | Xerox Phaser 8200 Laser Printer
TOSHIBA E STUDIO 280 fault code f100
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Toshiba e-STUDIO280 All-In-One Laser...
Fault 37,008.44:6069
That is a pre heater fault.
Most likley the pre heater needs to be replaced
Aug 29, 2007 | Xerox Phaser 8500N Printer
Xerox Phaser  8560DN Laser Printer Logo
198 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
