I have a Kodak EasyShare 5300 all in one photo printer. KSN P031022 I was printing pictures and it told me both black and color cartridges needed replacing. New cartridges were installed and all the pictures now have a pinkish purple overcast over the entire print. I removed both cartridges and printer head and unplugged printer. After about three hours, I plugged printer back in and reinstalled cartridges. Then cleaned printer head. This yielded the same result. I ran a Diagnostic Sheet on the printer and it shows Error Code: 3501. I now need assistance on what to try next.
  • 2 more comments
  • larpol Jan 15, 2009
    Your solution corrected the problem.
    Now it will not print any color and the black is very dim.
    How do I correct this?
  • larpol Jan 16, 2009
    When installing new cartridges, my printer does not have "have you installed new cartridges" on the menu.
    I uninstalled and reinstalled the program disc that came with the computer.
    It still will not print color at all and the black is dim.
    What do I do now?
    What do I do now?
  • larpol Jan 22, 2009
    When I was checking the print head again, I accidently moved the carriage to one side. I moved it slightly over and over again and eventially got color to print.
    However, it is not exactly right on photo prints.
    How do I get it back exactly right so the prints are true color?
  • 19,396 Answers
Clean also the cartridge sensor inside the ink carriage, using alcohol and soft cotton.
If you still get the problem, you may need to replace printhead.
The part may be ordered by calling the Kodak number listed on the owner manual.
Posted on Jan 23, 2009
  • 153 Answers
See if the print head is good r spoiled moving removing without proper assistance could hav caused tis problem check wit the circuit strip in the catridge is ok
Posted on Jan 22, 2009
    Sergeant:
    Champion:
  • 435 Answers
Hi, Can you try a test ?
Try printing any red color w/ only red catridge blue w/ only blue catridge green w/ only green cartridge black w/ only black catridge.
Now, we migh know wats going wrong ...
    Sergeant:
  • 221 Answers
As giving the cleaning printout from the pc many a times utilizes/consumes  lots of ink and makes the ink very less and this results in dim printouts.to resolve this just remove the cartridges from the printer give a ****/brisk 5-10 times  to the cartridges and then install.after installing print some 2-3 documenmts in best mode it will consume some ink but then adjust it to normal mode and continue till the end it will print properly.
Posted on Jan 16, 2009
  • 66 Answers
    President:
  • 2,110 Answers
Upgrade to the latest software and firmware from the Kodak website below.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?pq-path=9106
    President:
  • 1,990 Answers
Welcome to Fixya! Uninstall and Reinstall your Printer Software.
Posted on Jan 15, 2009
  • Travis Humphries
    Travis Humphries Jan 16, 2009
    Welcome Back! You will have to Replce the Print Head on this Printer. If not Comfortable Fixing this yourself, You may need to take it to an Authorized Service Center. Let me Know!
  • 101 Answers
When you install new cartridges, it should ask you if you have installed new cartridges,chose yes,then it will print an alliment page, which you put into the scanner..to correct alliment issues with your new cartridges,or you need to uninstall and reinstall the software ( disk) that that came with your printer. Hope this fixed ya!
    Genius:
  • 2,035 Answers
Error code 3501 is cover open error message To resolve this error condition, close the access door. The printer will not operate while the door is open.If the error message continues then you may need to replace the cover switch .This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located before try the power off it 30 min and power it and check it works ..
Good luck...
  • Anand Kumar
    Anand Kumar Jan 16, 2009
    # Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
    # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
    # Continue doing this until it looks clean.
    # Then dab the cartridge on the towel to make sure the ink is flowing.
    # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
    1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
    2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
    # Reinstall the cartridges, making sure you snap them correctly into the printer.
    Genius:
  • 1,913 Answers
No woory frisr pul the ink cartridge then check and clean it.also check ther eis not any palstic or dust on bottom edge.tehn refix it.
also check there is not any paper jam.
  • kishor khatri
    kishor khatri Jan 21, 2009
    refix ink cartridge in proper color ink tank.
  • kishor khatri
    kishor khatri Jan 23, 2009
    set good combination of cmyk or rgb in software u get good print .u can do it.
  • 679 Answers
Clean printer rod and cartages head and let me know if it will works.
  • 1 more comment
  • rockfixya
    rockfixya Jan 15, 2009
    if cleaning not works then upgrade to the latest software and firmware from the Kodak website>>
    http://www.kodak.com/global/en/service/d...
  • rockfixya
    rockfixya Jan 16, 2009
    please check out the given link.
    Thanks
  • rockfixya
    is the cartage are of same model?
I replaced the K cartridge and i get this caution. I-Unit End Replace K
If "[Color name] Toner Empty. Replace with a new toner cartridge." is displayed and printing stops, replace with a new toner cartridge.
([Color name] indicates one of the following: C or Cyan, M or Magenta, Y or Yellow, K or Black.)
Jan 10, 2017 | The Office Equipment & Supplies
BROTHER P-TOUCH IS not printing
It is obvious it has a failed electronic component, since these are not repaired/exchanged except when they are under warranty best thing to do is just replace it.
Jan 09, 2017 | Brother Office Equipment & Supplies
Need to change font size larger when printing
Change the font on your document before printing
Jan 12, 2015 | Office Equipment & Supplies
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
Canon mg6150 printer too much pink in photo's when printed
Please calibrate the printer using Canon software.
Mar 08, 2014 | Office Equipment & Supplies
Colour cyan not printing
Did all of the packaging come off the toner successfullywhen first installing. Can you see cyan toner on the transfer roller? (Black roller on actusl cartridge)?
Dec 08, 2013 | Office Equipment & Supplies
How to clean ink absorber for canon mp237
First of all open the ink cartridge of your printer.
When the ink cartridge would move all the way over, then disconnect the power cord of your printer.
Now pull the frame of rubber from the printer and remove ink pads.
To clean ink pads you may place them in a bowl having warm water and start rubbing and squeezing them to clean it from ink.
After removal of ink, keep the pads separate for dry.
When the pads get dry completely, place them back in rubber frame.
Reinstall the rubber frame in your printer.
For deep guide and support refer to-
Canon Pixma Mp237 Manual
Oct 07, 2013 | Canon PIXMA MP230 Multifunction color...
Laser printer makes light clicking noise when idle
When idle is potentially the fuser unit, after heating and cooling. However the print quality issue associated with the clicking sound could indicate an electrical issue. The HVPS maybe faulty causing the print quality issue (due to dependant parts) and the electrical click. In any case I would recommend calling Brother and finding the nearest authorised service agent.
Oct 20, 2012 | Brother Mfc-9840cdw All-in-one Laser...
k24674
