Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Hi, vacuum clogged and motor shut down, how do I restart. thx
Thanks
  • cisherwood13 May 11, 2010
    Could you explain further please? Where is the overload switch?
  • 66 Answers
I'm assumeing you have remove the clog so unplug the machine an let it set of about an hour then plug it in and before you turn it on get it ready to vaccum then turn it on the overload switch should reset and it should run
Posted on Jan 24, 2009
Vacuum shuts off while in use
There is a thermal reset inside the motor that shuts it off. There may be a clog.somewhere or something restricting the airflow, it could be clogged filters. If there are no clogs or restrictions it is possible the thermal reset is bad in which case you will have to replace the motor.
Jan 26, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
It was working fine and them just stopped it is not that old and was not making noises HELP!!
Vacuum cleaners have electric motors in them that require proper airflow to pass over them to keep them cool. Many vacuum cleaners have a thermal (heat) sensitive shut off mechanism built in. This mechanism should prevent the burn out of the motor. If you run a vacuum too long with a clogged hose or clogged filters (especially bagless vacuums) or clogged bags, that is essentially choking the vacuum for air and not allowing it to breath properly. This will cause it to overheat and shut down. Most of the big box store purchased vacuums have very thin wires in the motor windings and can only do this a few times before the motor completely fails. If your vacuum has been shutting down, then cooling off and restarting after about 30 to 45 minutes, then shutting down after only a few minutes of use, your machine is probably clogged up or the filters are compacted.
Jul 05, 2011 | Vacuums
I was using my Heritage 11 vacumn with the hose attachment and the motor shut down like the power went off .When you push the switch on the housing the light comes on but the motor does not run.
Hi, the motor could be overheating. Most vacuums have a heat sensor that shuts the vac. off if there is a clog. Let it sit, feel if it's hot. If so you may have a blockage of dirt etc. Try to clear it, let it cool and tart it up. I hope this helps, if not let me know with more details and we can narrow things down Chris
Feb 09, 2011 | Kirby Heritage II Vacuum
Clog and possible overheated
Hi Jen,
It sounds like your vacuum overheated due to the clog. This is a protection feature most vacuum cleaners have to prevent the vacuums motor from burning out due to a lack of air flow. The safety switch will activate and shut the machine off for a short period of time until the motor has cooled.
You should remove the clog from the vacuum, and make sure that your filters are clean. This model has a hidden filter directly underneath of the bagless dirt cup in a black tray that says "PULL". Pull this tray out, inspect the filter, and if dirty rinse under water until clean. Make sure that the filter is completely dry before reinstalling and using the vacuum cleaner again.
After inspecting all of the filters and removing the clog, let the vacuum cool down (usually just a few hours) and try to turn it on again. When you turn it on, remove the attachment hose and make sure that you have suction from the hose. When putting the attachment hose back down into the floor section of the vacuum, listen to see if you hear a change in the noise the motor makes. If you hear a higher pitched squeeling noise, this indicates that there may be a clog in the lower section of the vacuum as well. If the noise is the same then you should be ok.
If the vacuum continues to shut itself off, then either the clog has not been completely removed, or the safety thermal switch inside may now be faulty, and only at this point should you take your machine into a repair store.
I hope that this helped you!
Chris Jones
GoVacuum.com
Apr 14, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
Can the filter cause the vacuum to shut off?
Greetings from GoVacuum,
The answer to this question is yes, sometimes the filters can cause the vacuum to shut off. This typically happens when the filter behind the bag, or the pre-motor filter is clogged or dirty. Also if you have a clog somewhere in the system, this can also cause the machine to power down after a short usage time.
If the machines shuts down, and won't start until waiting for a period of 1-2 hours, then what's happening is that for some reason the motor is overheating, and to protect the motor from damaging itself because the motor can not breathe, it will shut it self down as a precaution.
This is either caused by a clog in the vacuums hose or power nozzle, or it can also be caused by a full bag, or dirty filter.
If the vacuum will not turn on at all, not even for a short time, this indicates something more serious then a clog or filter, and can be one of a number of things from the cord, or switch, and can also be an electronic circuit board, the motor itself, or the hose to vacuum cleaner may have gone bad.
If you can kindly be a little more specific on the problems that you are having I would love to try and diagnosis this thing to help you figure this out. I always happy to share my knowledge with others.
You may email me if you'd like, or just respond here with a clarification request.
If you found this helpful please help me out as I start here on Fixya by clicking the 4 Thumbs Up Icons in the top right hand corner of each repair.
Thanks again,
Chris Jones
Govacuum
Mar 20, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Dyson vacuum cuts off
hi this sound like a familiar problem of the motor o/heating due to lack of ventilation ? check the filters ok? remove the cover concealing the roller brush/beater and check for clogging at the underneath and housing clear it out properly easier to remove/lift out roller ? also clear out the clear bucket dust collector and most important the cone that fits into this canister has a cylindrical honeycombed/small holes(looks like hundreds? ) use a small pointed impliment to poke out all!!these holes as these are relative to vacuum within cylinder so if not clear ? motor no vent and result is no/poor vac and o/heat then thermo switch kicks in and shuts down till motor cools hope this helps best wishes from uk
Oct 27, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
The machine shuts off!! will restart after a few minutes, but shuts right off again...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=560313
Generic problem for all Vacuums
The machine shuts off!! Will restart
Posted by mjzimmervt on Apr 30, 2008
Will restart after a few minutes,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not knowing the brand name or model number of the vacuum, some vacuums have a thermal switch or thermal shut off switch to protect the motor and once the motor gets hot the vacuum will shut off, or the vacuum could very well be clogged and the air is not getting through to the motor to keep it cool. Please check your owner’s manual under the trouble shooting section or cal the factory / manufacturer to see if the can send you an owner’s manual (OM) or you can download the OM from the manufacturer’s website. Next time include the brand name and model #. ? So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Vacuum cleaner power loss
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=545672
Posted by fudpucker on Apr 25, 2008
Vacuum loses power while operating. Just shuts down and will not restart by toggling switch. After a brief (cool down?) period it will start.
Is there a breaker/reset? Does it have a feature that automatically shuts it down when the bag is full?
I can't locate my owner's manual, so am completely in the dark or dirt.
Depending on the Brand name and Model # there is what they call Thermal Switches on some of the vacuums that prevent the motor from over heating and possible burn out of the motor If the hose is clogged, the bag is full or the filter is dirty and the air does not flow threw the filter. Any one of the three situations could cause the vac to say “cut out” and stop the motor. So check with your local vac dealer.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Vacuums
Orange light is on
You may have a clog, which over heated the motor and it shut down. Clog could be in the hose, the dirt inlet by the brush roll and bag/filters. Some have a reset on the back, near the bottom. If not, then the over loard protector may have gone bad, could also have a motor problem.
Mar 22, 2008 | Royal Procision 7050 Bagged Upright Vacuum
Vacuum shuts down after a short time and needs to cool off before being restarted.
Could be the protector, it usually is located by the motor. But I am sure that this has a 1 year warranty on it, so if it is less then that, take it in for warranty service. But it also could be that you have a clogged filter, hose is clogged, or the dirt inlet by the brush roll is clogged. A clog will cause the motor to overheat and shut down until it is cleared.
Feb 29, 2008 | Dirt Devil Reaction Twin Cyclone Upright...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
156 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
