Question about Frigidaire GLER331A Electric Dryer
Dryer gets hot to the touch
I recently moved to a condo and discovered that the existing dryer hook-up is a 3 prong plug. So i swapped out my dryer's 4 prong cable for a 3 prong cable. I took care to hook it up correctly per the instructions. I made sure to ground the dryer frame to the center post ETC... I went to use it and the top right back corner and the backside of the dryer get extremely hot and... the clothes take for ever to dry. FYI. Could something have happened during the move?... could I have hooked up the new power cable incorrectly? any suggestions? thanks
  • mitdrum Jan 15, 2009
    I should have mentioned that I checked the venting and that is all clear. there seems to be pretty good flow air coming out of vent outside the condo.
  • Anonymous May 18, 2009
    mitdrum - did you ever get the problem fixed? I have the same issue
  • 126 Answers
If you didn't install new venting I'd start by checking the vent hose from the back of the dryer to the outside vent hood to make sure there is no blocked airflow. Could be something else but that is where I'd look first. Good Luck.
Posted on Jan 15, 2009
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
Going from thre prong to four prong what goes
Under the new Codes2_bing.gif...all dryers (and stoves/ovens) must now be 4 wire....having a seperate neutral and ground wire in NEW construction. In decades past, the neutral was allowed to serve as both - the neutral and ground - typically by means of a solid metal strap or wire strap that bonded that connection to the metal frame of the dryer. This sounds as if it is the case in your existing dryer...which was typical.
But...the old arrangement wasn't always reliable...and a seperate dedicated ground provides a greater safety path in the event of a fault inside the dryer (lowering the chance the user may get a shock when touching the frame of the dryer).
To modify your existing 3 prong dryer over to 4....you'll need to remove the 3 wire - disconnect the ground strap (or wire) that bonds the neutral to the frame of the dryer...and install your 4 wire so that you'll have (from left to right) one hot, one neutral, one hot connection...and connect the ground directly to he frame of the dryer (there is usually a green screw near the dryer connection block for this ground)
For more on this - with an illustration, see:
http://www.american-appliance.com/service_pages/electric_dryer_cord.htm
When done properly, you can test for correct wiring and connection with an ohm-meter (continuity check)...by checking for continuity from the ground prong on the plug to the frame of the dryer...you should see continuity. Then check for continuity from the neutral prong on the plug to the frame...you should NOT see continuity....nor should you see any continuity between the neutral connection at the wiring block to the metal frame.
The whole purpose of the Code change to the 4 wire is to seperate the two.
Hope this helps,....if you need more details, please follow-up.
May 02, 2010 | Speed Queen AES28AWF Electric Dryer
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool Dryer - Model LHE 5700. My Dryer had a 3 prong plug. I recently built a house which has a 4 prong plug. I changed out the plug and connected the wires according to color. The center wire is white...
Hello David_Teresa,
Under the new Codes...all dryers (and stoves/ovens) must now be 4 wire....having a seperate neutral and ground wire in NEW construction. In decades past, the neutral was allowed to serve as both - the neutral and ground - typically by means of a solid metal strap or wire strap that bonded that connection to the metal frame of the dryer. This sounds as if it is the case in your existing dryer...which was typical.
The whole purpose of the Code change to the 4 wire is to seperate the neutral from ground to provide additional safety for the user.
Nov 29, 2009 | Whirlpool Dryers
I was switching the electrical cord from a 3 prong to a 4 prong and grounded a hot wire. there was a big pop and now i cant get it to start. would i have blown it up?
WHy are you switching the cord from a 3 to a 4? If the dryer came with a 3 prong cord and its a 3 prong terminal block, then i dont think you can change it to a 4 becuase you will short circuit. DOes the terminal block where your cord was hooked up have 4 terminals. Each termial can only have one lead/wire to it. check your circiut breaker panel? Is the circiut breaker tripped?
Jul 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Need to install a 4-wire/ prong dryer cord strain relief assbly
The green wire attaches to the dryer cabinet. There should be a green screw in the cabinet for attaching the wire. If not, you can always drill a hole for a ground screw.
The loose green wire you see is the reason the code was changed to a 4-wire cord.
May 06, 2009 | Kenmore 62602 Electric Dryer
Changing my dryer cord from 3 pronge to a 4 pronge. how do i hook the cords to the baqck of the dryer. brand name is a frigidaire
on 4 wire, red and black is hot, white is neutral and green is ground. On terminal block out side terminals are hot and center is neutral, ground connects to green screw on cabinet. if your current connection has a white or green/yellow jumper on the ground term move this to the center/neutral connection with the white wire. only wire to be on gnd term in gnd wire. hot does not matter which side as long as it doesnt touch anything else and not on center term.
Difference in 3 and 4 is a dedicated ground, on 3 wire dryer was grounded through the neutral.
May 03, 2009 | Dryers
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Mar 30, 2008 | Amana NDE2330AY Electric Dryer
Frigidaire GLER331A Electric Dryer Logo
153 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
