Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Hoops i have a singer futura ce200 with no big or small hoops where can i buy them.
I found both hoops on this websit.....thesewingcenter.com...lrg...13.99, sm...12.99!!!!! it took me 2 months of web seaching to find tem
Posted on Jan 15, 2009
Lights blinking on singer futura
The most likely cause of this is the needle is not ALL the way up, although it may look like it is. The CE machines are VERY sensitive to the needle position. The second cause is putting on the small hoop and turning on the machine; with the small hoop on, it cannot set to its default position. If you want to use the small hoop, leave all hoops off, then put in on AFTER you have turned on the machine.
Jan 19, 2014 | Singer CE-200 Quantum Futura Computerized...
What embroidery download formats can be used on singer ce200
It depends on your software version. The list of supported formats could be found in the manual, on Futura support site or checked right through the sofware menu (File->Open, File->Save as)
Apr 28, 2010 | Singer CE-200 Quantum Futura Computerized...
There is a patch for Windows 7 at www.future-support.com. That site is an amazing resource for the Futuras!!
Apr 14, 2010 | Singer CE-200 Quantum Futura Computerized...
My futura ce200 is driving me insane because i have the small hoop selected on the computer but the machine thinks that the large hoop is selected. How do i fix it??
Before attaching small hoop, turn on power switch to
move the carriage to embroidering standby position, and
turn off power switch.
check troubleshooting in manual
user manual link
http://www.futura-support.com/files/CE200-Eng_Fre_Spa040607.pdf
hope this helps and you get it working soon =)
Feb 05, 2010 | Singer CE-200 Quantum Futura Computerized...
Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
Nov 16, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer Futura CE 150 not recognizing small hoop
Except advices from the previous posts I suggest to check out whether you install small hoop precisely, there should not be any deflections, you need to insert it on the full length and fix it very well.
Sep 06, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer futura ce-200 problem, pattern mis-alignment
I have had similar problems in the past.
Do you hear a noise from the embroidery unit when the misalignment occurs ? If so, I suspect that your issue may be that you have some resistance under the hoop. Is there extra material that may be rubbing on the machine or catching somewhere. I have found that if I use some masking tape to keep all of the extra material from hitting any other parts of the machine or dragging under the edge of the hoop this error does not occur. FYI: I also stopped using the "optimize stitch speed" option at the same time. I believe that material dragging was causing the problem, but I still wonder about the stitch speed optimization feature.
Jun 03, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer Futura CE200 Software
If you use the standard FUTURA software. you will have to buy an add-on for the Software.
Singer offers an add-on called Hyperfont which allows to digitize any true type font on the computer.
The software is available in stores and online, but be sure to get the right version for your software. There are versions for the Futura CE150, CE 250 etc, and there are other versions for the CE100 and CE200, so be careful.
You should also keep in mind that although you can digitize any true type font with this software, not every font is suitable for embroidering and will stitch out nicely.
Sincerely yours,
Aki
Apr 01, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
71 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
