Question about Toshiba Satellite M30-S350 Notebook
Can't fax - modems not being detected
Never used this laptop for faxes, but want to set it up. But Standard Modem on Com 8 isn't being detected by Fax Console even though its there, enabled, etc. There is also supposed to be a preinstalled V9 modem but that is nowhere to be found on the Device Manager, and when I tried reinstalling that from the CD that came with the laptop it goes through the motions, but nothing happens.
    Problem Solver:
  • 15 Answers
Ok, a modem on COM8 ? Normally modems are on COM1, COM3. You need to fix that problem first. Most softwares are not setup to scan that high for the modem. (ps: COM2, COM4 are usually for other devices - in the old days, mice were on COM2). Follow instructions:
START
CONTROL PANEL
PHONE/MODEMS
Click over to MODEMS
Click on Proper MODEM
PROPERTIES
ADVANCED
ADVANCED MODEM SETTINGS
Change COM8 port to COM3
click OK, probably going to have to restart computer.
Let's see if this actually solves the issue. if it did not and you need more help, contact me through this site and we will proceed forward.
Posted on Jan 15, 2009
Fax from computer
First, you will need a USB fax modem. Then you use Windows Fax & Scan program to create/forward new fax documents, or even send a file as a fax or email.
Setting up your external modem to work with an internet telephone line is simple. Simply put a 2 way splitter into the internet modem telephone jack. Plug your telephone into one input and the external fax modem into the other. Then you can even dial from your computer routine telephone calls too.
Need more explanation? Let me know.
Mar 14, 2014 | Brother MFC-7460DN
My computer does not recognize my modem so I can send a fax.
2 completely different technologies.
FAX uses phone line (analogue) and router is digital.
It's one or the other.
Plugging what is essentially a modem into another modem was never going to work.
Scan and email is much faster and easier.
Or FAX to FAX through phone line.
May 14, 2017 | Computers & Internet
I am using a cable modem and a router on a laptop. I do not have a phone line. Am I able to fax using Windows 7? The computer states that I do not have a built in fax modem. I have an HP printer with...
For regular faxing a modem connected to a standard phone line is required, normally.
There are many websites devoted to allowing you to send faxes online that would suit your current needs perfectly. please see the following two links, these are services that can assist you in doing exactly what you need to.
Site #1
Site #2
NOTE: There are MANY more but these are two of the most prominent.
May 04, 2011 | Computers & Internet
DFM 562IS (DFM-562IS) Modem: SIR PLEASE SEND ME ITS ALL FEATURES.......
Product ID 3409 Brand D-LINK Vendor Code DFM-562IS Description 56K V.92/V.90 Software-based PCI Modem
The DFM-562IS is a software modem card. It plugs into a PCI expansion bus slot of a desktop PC. It supports voice, fax and data transmission/reception. It's a high-performance CONEXANT-based modem card, and can be used to connect to the Internet, and for fax and voice communication.
Key Features
High speed External Data/Fax/Voice
Plug and Play Installation
ITU-T V.92/V.90/K56flex Auto Detect
Fax Mode up to 14400bps Transmission Rate
Technical Specifications
Data ITU-T V.90/V.92
K56flex
ITU-T V.34, V.32bis, V.32, V.22bis, V.22
Bell 103 & 212A
V.44, V.42bis & MNP 5 (Data compression)
V.42bis & MNP2-4 (Error correction)
V.80 (H.324 video conferencing interface)
FAX V.17 (14400bps FAX)
V.29 (9600bps FAX)
V.27ter (4800bps FAX)
Voice With voice support via sound card application
System Requirements Requires CPU with MMX support
Operating Systems:
Windows 98,
Windows ME,
Windows 2000,
Windows NT 4.0,
Windows XP
Manufacturer D-LINK Warranty 2 Year Manufacturer's return to base Link D-LINK DFM-562IS Internal PCI 56K Voice/ Data Software Modem
May 03, 2010 | Computers & Internet
Connexant modem can receive a fax but does not see
This is often caused by the wrong country setting in Windows, as different countries use different dialtones.
Make sure your computer is set correctly in Regional and Language Options in Control Panel.
Apr 22, 2010 | Conexant chipset 56K V.92 PCI Data/Fax...
Winfax Basic
If you have the fax # correct, than it is the responsibility of the fax recipient to correct the situation. You cannot make a parametrical changes to someone elses fax machine. Thank you, Dana
Jan 18, 2010 | Symantec WinFax Pro for PC
Slow Fax Transmissions with USR V92 External fax modem
Its possible you've set your faxes to send in FINE resolution (200 dpi), I am not sure about MS Fax, but in WinFax you can select both Standard Resolution and Fine resolution as the default for sending faxes.
Jan 14, 2009 | 3Com U.S. Robotics Faxmodem 56K
DRIVER NEEDED: INTEX FAX MODEM SMARTLINK (PCI Modem)
use the software like driver detective, get it from the net, it will tell you the chip, then search ,
or search it on driverguide.com
Oct 31, 2008 | Smartlink (I56KSPF00) Modem
How fax work in DFM-560EL
my windows XP detect my PCI smart link modem
but can't find the driver for it
Oct 28, 2008 | Computers & Internet
What modem do you choose in step 2 when setting up winfax pro with your cell phone as a modem
If WinFax is asking you to select a type, its probably because it didn't detect a fax modem.
Make sure your modem works in Windows first If you can dial out of your computer using your cell phone using Windows, and your modem supports fax class 1 / 2 / 2.0 , then it MAY work.
Oct 13, 2008 | Symantec WinFax Pro for PC
Toshiba Satellite M30-S350 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
