Question about MSI K8N NEO Platinum Nforce3 Athlon64 250Gb Chipset 800MHz FSB DDR400 Socket 754 ATX Motherboard wit... (MB75MIK8NNEO)
Boots with message-File missing or curupt WINNT\SYSTEM\vgaoem.fon
Windows XP pro - 1st boot, floppy, CD, then HD.
Sometimes reboot and would run windows but would lose short cuts fom desk top.
Changed battery as it looked low and put Bios in Safe Mode but now it stops with above message always. Tried putting Windows CD in, it won't start, press return and it reboots and stops at above message. I then tried to reformat HD to load a backup but it will not bootup on Floppy or CD only hard drive
Any ideas? If not can you recommend a replacement MBd that will take my single core CPU AGP card and memory as I believe this board is no longer made.
  • 1 more comment
  • terry304 Jan 16, 2009
    Thanks for your help but this would'nt work.
    I have set floppy as 1st boot, if there is a Dos floppy in that drive and you reboot, it should load the Dos, Windows should not attempt to load but Windows loads and floppy dose not start. This is why I feel it must be on the mother board, what do you think?.
    Terry.
    Yes, after resetting Bios, changeing battery, putting Bios in safe mode, I have set Bios to boot Floppy, CD, then Hard disk but it ignorse first two and always boots with Hard disk first. This is why I feel it must be mother board.
    Terry
  • terry304 Jan 23, 2009
    Thanks for all your help folks, it did'nt sort it out so I've bought a replacement main board.
    Thanks again.
    Terry.
    President:
  • 2,351 Answers
Hi terry304, your current trouble is within windows not your motherboard. If you want to repair your windows than go to the link below & read the Microsoft page. They have a program that can help repair your window. See the link provided;
http://support.microsoft.com/default.aspx?scid=kb;en-us;307545
(Though you'll do most of the work).
Here are a few replacement boards for your socket 939 CPU & MB;
http://www.outletpc.com/c3980.html
http://www.newegg.com/product/product.aspx?Item=N82E16813131568
And lastly:
http://www.winbuyer.com/cat-1717/keyword-motherboard%20939/init-1/?c=8201717&gclid=CMCpoPubkZgCFQpxHgodKmPDmg
Personally, I do not buy from EBay when it comes to MB's. The risk is too high. I also run a socket 939.
Good luck Terry!
Thank you for using fixya.
More question? Post here.
Mike
Posted on Jan 15, 2009
  • Mike Peluso
    Mike Peluso Jan 16, 2009
    Terry, you can access your CD-ROM drive by pressing the F8 key during boot up. Load your Windows CD in to the CD-ROM drive. The F8 key will load a screen like this;
    From the "Please select boot device: window, select your CD-ROM drive that has the windows CD in it. Than try a reinstall of windows. (Preferred with a format of the hdd).
    I have been doing this for sometime & once windows has been reinstalled your current issue will clear up. I am sure your windows is messed up. Cause could easily be from a virus or worm. Though rare, bios could be corrupt. Before you do a format & reinstall window, remove your memory & reseat, this will clear any memory resident virus that may reside in your memory.
    If you still feel the problem is the motherboard, I did list a couple replacements.
    Mike
    Problem Solver:
  • 7 Answers
You have to change bios boot setting to boot from cd first
  • ironclaw Jan 16, 2009
    terry try a new power supply first .sounds like your power supply is dieing .
My ABIT sg-72 motherboard boot attempt from HDD says "NTLDR is missing". The only Enabled boot device is HDD. If I change boot device in setup to CD (Windows XP distr disk), that boots up and...
first check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
check that there are no CDs or DVDs 3 1/2 inch floppy discs
in the CD/DVD,3.1/2 floppy drives ,and no removable usb drives plugged in to the usb ports
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
don
Feb 13, 2011 | Abit SG-72 Motherboard
I am getting a disk 1/0 error and am not confident at all with computers. How can I fix this so my son can use the computer? My PC is about 6 years old and I only ever used it 9-10 times
A..Access the BIOS setup by pressing the key designated for your BIOS at Startup? It can be Del/F1/F2 or whatever and will be shown on Boot Screen before Windows is loaded.
B. Do you have a Win98 Boot Diskette proven to work well in a PC?
If so:
1.With the Win98 Boot Diskette in the Floppy Drive, Restart the PC.
2. Press the BIOS key [Eg:Del] enter BIOS setup
Check for correct YYYY/MM/DD and Time for your Time Zone and proceed to take a good look at the entries of your IDE devices and Floppy Drive with special attention to your Hard Drive(s) in IDE section. If they are all properly identified and normal, you can EXIT the BIOS. [ It does not mattere "Save changes" or "don't save changes" as you have not made any changes.]
3. Wait for Boot Disk to be accessed and Windows Startup Menu to appear with the Options:
1.Start Computer with CD-ROM support.
2.Start Computer without CD-ROM support
3. Help File
4. Select the option,1.Start Computer with CD-ROM support. and ENTER
5. Watch the screen for CD-ROM driver installed successfully" and "Diagnostic Tools " installed and CD-ROM drive letter designation and finally appearance of A:\Prompt
6. At, A:\ Prompt type FDISK and press ENTER.
7. Accespt Y at the bottom of "Large Disk Support" message.
8. At FDISK menu select #4. Display...."
9. Check if the HDD is shown as C: A FAT32 and size.
I am suspecting a problem somewhere here; so if you don't have an Active C: drive press ESC >ESC and remove boot Disk CTRL +ALT+ DELETE to reboot and post back
If you have an Active C: drive, press ESC >ESC to A:\Prompt and type in C: and then at C:\> prompt, type DIR and [ENTER] look for Windows Directories. Here is another Problem area. If you cannot Find any Dir or get an Error, make sure your typing and spacing are OK [ No space after Drive letter for the Command] and if so, ALT+CTRL+DEL or Power Off.
If the problem is same do next .
Alternative Start Mode
1. Re-boot PC, as it starts tap F8 several times until the windows boot window appears.
2. Scroll to "Start with last known good configuration.)
3. Press "Enter"
Or
2. Scroll to "Safe Mode" (With networking, if you want to access the internet)
3. Press "Enter"
System Restore
1. Go "Start"
2. "All programs"
3. "Accessories"
4. "System tools"
5. "System Restore"
6. ensure "Restore to an earlier time" is checked and click "Next"
7. Select an earlier date when your PC worked well. (Must be a highlighted date)
8. Click "Next"
9. Allow system restore and reboot
NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
Computer is booting from a non-bootable source.
Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and/or NTDETECT.COM file.
Misconfiguration with the boot.ini file.
Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
New hard disk drive being added.
Corrupt boot sector / master boot record.
Seriously corrupted version of Windows 2000 or Windows XP.
Loose or Faulty IDE/EIDE hard disk drive cable.
Solutions:
CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows 2000 users
If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect
Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the root directory of the primary hard disk drive. For example, C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers.
Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516.
Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive.
copy ntldr c:
copy ntdetect.com c:
After the above two files have been copied, remove the floppy diskette and reboot the computer.
Windows XP users
Insert the Windows XP bootable CD into the computer.
When prompted to press any key to boot from the CD, press any key.
Once in the Windows XP setup menu press the "R" key to repair Windows.
Log into your Windows installation by pressing the "1" key and pressing enter.
You will then be prompted for your administrator password, enter that password.
Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
At the A:\> prompt type:
sys c:
After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
If you are attempting to add a new hard disk drive to the computer make sure that drive is a blank drive. Adding a new hard disk drive to a computer that already has Windows installed on it may cause the NTLDR error to occur.
If you are unsure if the new drive is blank or not try booting from a bootable diskette and format the new hard disk drive.
It's possible your computer's hard disk drive may have a corrupt boot sector and/or master boot record. These can be repaired through the Microsoft Windows Recovery console by running the fixboot and fixmbr commands.
Additional information and help in getting into the Microsoft Windows Recovery console can be found on document CH000627.
If you have tried each of the above recommendations that apply to your situation and you continue to experience this issue it is possible you may have a seriously corrupted version of Microsoft Windows. Therefore we would recommend you reinstall Microsoft Windows 2000 and Windows XP.
If you are encountering this issue during your setup you may wish to completely erase your computer hard disk drive and all of its existing data and then install Microsoft Windows 2000 / Windows XP. Additional information about erasing the computer and starting over can be found on document CH000186.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Hope this helps ,
Jan 26, 2011 | Gigabyte GA-8SRX Motherboard
Gigabyte Ga-K8N Pro Windows XP Installation
Download "MEMTEST86+" from the Internet.
One version boots from a diskette;
another version boots from a CD-R (that you have created).
Either way, make MEMTEST do a "full" test of the RAM in your computer -- bad RAM can cause "unpredictable" crashes.
Sep 13, 2009 | Gigabyte GA-K8N PRO nVIDIA nFORCE3,...
I can not boot my system from the CD to fix file problems.
It might be a heat problem. Check if internals fan are spining well. .... sometimes you should get an error message before going black, check if so, let me know.
Jan 20, 2009 | Iwill KK266 (MAKK266) Motherboard
Driver to Floppy? Won't Fit? Going Crazy...
Before you install drivers you must first install operating system to do this check BIOS is set to boot from cd then insert Operating system cd and reboot. When operating system installed then install motherboard drivers and any others that are needed
Jul 22, 2008 | EliteGroup 661FX-M7 (661FXM7V11)...
Cd rom message "no emulation" when booting the windows xp installer
when i install my windows xp professional i get a message prompting BOOT TO ATAPI CD-ROM: "NO EMULATION".... how can i fix this?Pls help me on this
Jun 07, 2008 | ASUS P4SP-MX Motherboard
Installing XP on a PCI SATA Card
hey change ur boot order in bios.....
put dvd/cd drive 1st...
May 30, 2008 | ASUS P4S800-MX Motherboard
Computer
1st make a backup of all the data you want saving.
2. find out your recovery cd or operating system cd.
3. insert the cd and then reboot.
4. on the start up key the first screen you see about 3 secs after turing back on hit the hot key.
could be F2 or F8 depends on your mother board.
if its neither of these watch carefully on the startup screen it should tell you wich key it is but be quick cause it will only be up for about 2 secsa :-)
when the cd boots up just follow the instructions.
please rate my solution on how it helped you.
any more quiestions or if u get stuck just reply to this post.
Dec 16, 2007 | Intel Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Computers & Internet Logo
752 people viewed this question
Top MSI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Mark Taylor
Mark Taylor
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
