Question about Intel Motherboard
Hard drive configuration
Dont know what i need to use a new sata hard drive with an old msi 4xp ultra3 motherboard. it presently has the old style hard drive
    Sergeant:
  • 238 Answers
If your motherboard does not support SATA, then you will need a SATA controller like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16816132001
This will require an empty PCI slot.
Posted on Jan 18, 2009
  • 54 Answers
Look for a sata connector on your main board that looks like this:
http://images.tomshardware.com/2005/11/23/pc_interfaces_101/sata.jpg
If your main board does not have one of these connector then you do not support SATA. If it does make sure you connect the drive in SATA0 or SATA1 what ever is the lowest. Also SATA does not require any jumper configuration.
Posted on Jan 15, 2009
What is sata
Go to this site and it explains what SATA is. Its the new hard drives that replace the old IDE (now called PATA) hard drives in computers. Much faster and better than the old drives.
Copy this site
http://www.wisegeek.com/what-is-sata-or-serial-ata.htm
and paste it in your ADDRESS BAR and hit ENTER.
Hope this is of some help. Bud
Aug 10, 2010 | MSI 661FM-L, 601-6540G-010, Microstar P4...
Connect the SATA Hard Drive to MSI VIA VT237R motherboard
go into the setupn and enable the sata settings if you are useing a ide cd drive youll have to enable both sata and pata drivs
Jul 21, 2009 | Intel Motherboard
New sata hard drive fitted, now says no audio deviec ,so no sound
If you just added the sata and reformatted the drive with a new copy of the Operating System you will need to reload the sound drivers located at MSI's web site in there drivers and download section.
May 22, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
New SATA Hdd detection problem
Have you checked in the bios setup of the motherboard if your SATA ports are enabled?
Let me know if you need further assistance.
Regards,
Graemevm
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
MSI motherboard - SATA Hard Drive
Hi again!
Here is the manual, the drivers and everything else there is abut that mobo of yours.
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=152
You need to change the settings in the bios, the settings how your motherboard reads the disks. You will find it in the manual-
Good luck
Nic
Mar 12, 2009 | Intel Motherboard
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Feb 09, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
Problem with IDE & SATA Hard Disk
Have u tried changing ur jumper setting..which u can find near the power cable to the hard disk...and also U have to enable SATA hard disk in BIOS..
Dec 18, 2008 | MSI K8N Neo Platinum Motherboard
Sata Port Connector is not avtivating
I had the similar problem with the K8MM-V Motherboard. I has been using a PATA HDD. I need to intall a 250Gig Seagate SATA HDD. Despit all the Bios Configs the PC Could not detec the HDD. Untill i Put a Jumper on the HDD  limiting the SATA HDD to 1.5gig of OS instead of 3gig. Look at the Label of your HDD
Oct 28, 2008 | MSI K8MM-V Motherboard
Msi p4m800pro ide issues
No Boot (system does post) - Hard drives not detected • Check jumper settings on all IDE devices • Verify that IDE controller is configured correctly in the BIOS • Check to make sure that the drive is connected to the correct controller • Make sure drives are configured correctly for RAID • Verify Onchip IDE configuration for ICH5 SATA operation is set correctly • Test drives with different IDE/SATA cables
Dec 19, 2007 | Intel Motherboard
Fitting New SATA Harddrive
Hi, google msi, click mainboard, click download, click manualy download, click AMD, click ARCHIVE, you will find your mobo here listed as "MS657" everything you need will be there. Goodluck mistyman
Sep 02, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Intel Motherboard Logo
47 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
