Question about Mintcraft CC970 Air Blow Gun 13"
Good day i think i have a release problem with my mint craft 6 gal 2hp air compressor. it will not release all the air from the engine so when i restarts it goes very slowly and to rectify this i have to release all the air to restart and fill up the tank. Q - where is the release valve to try and fix or can i
  • 979 Answers
You may have a bad valve which is internal. This could be very costly. You may want to consider a new one. The cost of repair could literally be more than a new one.
Posted on Feb 11, 2009
How do you replace a belt on ***** air comprester
Most modles you can either loosen the pump or the motor and slide them together. the belt should roll right off.
Sep 15, 2014 | Husky Air Compressor. 2 Gal. Portable...
Why wont my air compressor hold pressure
i dunno how it works but there should be a little pin on it and try pushing it in
Dec 01, 2012 | Husky Air Compressor. 2 Gal. Portable...
Pratically new craftsman dry pump air compressor will not reach shut off pressure, reaches 100 and will not get higher it just continues to run.
The compressor valves may require replacement, the drive belt is loose, or there is a leak somewhere on the tank--usually the safety release valve. Hope some of this helps!
Oct 16, 2010 | Craftsman 20 gal Horizontal Compressor
My PC compressor buids 42 psi and continues to run without building more pressure or shutting off
Look for massive air leaks all around the machine including the safety 'blow-off' valve. The compressor diaphragm may have a hole in it. If this machine is new, return it to the dealer and get your money back or at least get it repaired under warranty. Good luck!
Apr 05, 2010 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
How long does it take for the compressor to fill up during the first use? The motor has been running for 15 min and the pressure needles have not moved....
If the machine is new, take it back to the dealer and get your money back or at least have them get it repaired under warranty. It would appear that the diaphragm has a hole in it or it has a missing valve assembly in the compressor itself. Have you checked around the machine for large air leaks? Check the safety 'blow-off' valve for any leakage? Look for missing tank plugs or a missing shut-off valve at the air exit point. Good luck!
Mar 20, 2010 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Air leaks via the head so tank does not maintain pressure
The air leak you have described is probably from the unloader valve which may not be seating after it dumps cylinder pressure. If you can find a good manual for it, disassemble the unloader valve and check for contaminates or build up around the seat. The differential spring may have lost it's value also, in which case you will need to replace the unloader assembly.
Jan 20, 2010 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Porter-cable compressor stops and restarts at about 60psi
You prolly have a leaky gasket in the main valve. Air is leaking and causeing it not to go about 60psi, you probably have it set to reach a high PSI but since the leak is not allowing it reach above 60 it keeps cycling trying to get above it
Aug 27, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
The compressor only reach 50 PSI.
Does the compressor continue to run but not build more pressure? In which case it is an air leak most likely, or does the compressor shut off at 50 PSI? In which case it is mose likely the pressure switch. If it is an air leak you can un-screw the guage and coat with putty or teflon tape and reinstall to clog the leak around the threads..
Jan 26, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Mintcraft CC970 Air Blow Gun 13" Logo
59 people viewed this question
Top Mintcraft Tools & Hardware - Others Experts
John Trevino
J.D. Browning
J.D. Browning
Are you a Mintcraft Tool and Hardware - Other Expert? Answer questions, earn points and help others
