Question about Compaq Armada E500 Notebook
Compaq Armada E500 shut off and won't restart.
Thank you for your interest. Here is the order of events.The adapter was plugged in. The green led appeared on the adapter indicating ready. The cord was then inserted into the computer. The "on" button was pressed. The monitor turned on. The "Compaq" logo was briefly displayed. A low popping sound emanated from the machine. The sound appeared to originate near the "on" button area of the machine at the back. The computer shut off rapidly. I tried the power button again. No luck, it would not power up at all.The cord to the power adapter was then checked for integrity. The green light remained lit on the adapter. The cord was tested with my multimeter. Output voltage appeared normal. The battery was removed from the machine. The unit was left alone to drain any residual voltage. The power cord was reinserted. No luck. No smell of burning was ever discernible. I am at a loss at this point. Can you point me in a new direction?
    Novelist:
  • 140 Answers
The notebook does have an overvoltage and overcurrent protection inside the computer itself. The problem is definitely in your low voltage power supply section of your notebook. Since you do have a multimeter and know how to use it. Take your notebook apart so that you can see the board that your power adapter actually plugs into. Your notebook may just have a normal fuse that you can see is blown since they do make that little popping sound and do not leave any discernible smell of an electronic component that burned or blew up so to speak. That you cannot smell anything like that is good. If you do not see a regular fuse, there are what are called bell fuses that look like miniature glass diodes or resistors but are actually inline fuses. Your entire notebook should not have more than two or three. Sometimes they are made of ceramic, but that is only used for high amperage uses like on plasma screens and such. If the fuse is visible and checks blown try another one and watch it as you power the computer up. If it blows again check your on/off switch without power to your computer to be sure it is not shorted out. Then trace your voltages into your computer with power on and see where you do not get any voltage down the line. It is pretty straightforward in tracing the voltage from your adapter into the computer. Remember though that the intial voltage from the adapter is broken down into smaller voltages for the logic circuits. It is apparent you are not getting any voltage past right inside your computer's power supply and voltage regulator section. You in my opinion have an open circuit instead of a short right now. If you find fuse and it blows again then you have to find the shorted component. Let me know and I will be glad to help further. Good luck.
Posted on Jan 15, 2009
Hi can you help me restore my compaq armada e500 to factory settings as i have forgotten password on main screen. i dont have a disc or that.
If you mean BIOS password, then you can do the following:
- plug out AC,
- take out the battery,
- press down Fn and hold it pressed,
- plug in AC,
- continuously tap on F11
this should lead to cycling LEDs on and off.
If so, let the sysetem boot. You should then receive the POST-msg "options not set".
If it is a Windows password, you can follow the instructions here
Hope this helps
Lucas
Jul 07, 2011 | Compaq Armada E500 Notebook
CAN I USE INTERNET THRU WIFI WITH COMPAQ ARMADA E500 ?
it seems like your laptop not have inbuilt wi-fi connection, so you can not use the wi-fi but if you buy a USB wireless adapter or wi-fi pcmcia card so you can use the wi-fi in your laptop.
Thank you for using Fixya
Regards
Manish
Jun 13, 2010 | Compaq Armada E500 Notebook
How can i connect a wireless internet connection with a compaq armada E500
Get a PCMCIA to USB2 adapter that has an external 5 Volt connection to it to supply the higher current for the wireless adapter. The power can come from the USB via USB adapter cable
After installing the adapter, the USB wireless device should be installed just like in any later notebook. The wireless device requires USB2 and high power. and won't work off a powered hub.
Feb 05, 2010 | Compaq Armada E500 Notebook
How do you refresh compaq armada E500?
what do u mean by refresh ?
1. restart
2. restore
3. refresh screen
Dec 31, 2009 | Compaq Armada E500 Notebook
How to charge battery in compaq armada e500
You need to connect the power adapter and charge it for some time and check.
May 09, 2009 | Compaq Armada E500 Notebook
Ethernet
I have an Armada E500 and its a Intel(R) PRO/100+ MiniPCI Ethernet Adapter.
Hope this helps..please rate me!
May 03, 2008 | Compaq (198721-001) Modem
NO DISPLAY FAN NOT WORKING
Try external monitor!If it work the problem is VGA!
Dec 07, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
107 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
