Question about Motorola Mobility RAZR V3
Speckled Inside Screen
Hi, My razr turns on and then displays a multi-colored speckled screen, sometimes it has large icons also. Your help is geatly appreciated. Thank you.
    Brigadier General:
  • 7,752 Answers
You need to have the lcd replaced on the phone.
Posted on Apr 15, 2008
I have a Sanyo PLC-XP50 projector and my words on the screen are showing up white with purple speckles, when I want them just to be white.
there are a lot of dust on the Lcd panel
3 panels (red ,blue,and green) in the Projector
purple speckles means that the dust on the Green ,
1,pick the Lcd prism from the projector
2,clean it by putting it into water,with some cleaner
3,dry it with a hair dryer
4,ok
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 19, 2014 | Sanyo Office Equipment & Supplies
Printing from coreldraw 5 to zebra p330i
Sounds as though your printer is dirty, there are unfortunately no different color matchin schemes for this particular printer. The printer operates on an RGB interface, even though it prints using YMC. As far as the speckled look, this typically is due to dust during printing.
Aug 08, 2012 | Zebra P330i Thermal Card Printer
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Color output to screen lacking red
You have ruled out the graphics chip by plugging an external monitor in, the chips fine.
Now you have to look at the inverter. Sometimes a cable will work itself loose from the inverter, causing the display to go wild and show strange colours where is should be white.
What you have to do is remove the screen bezel (the plastic screen surround) this reveal the screen, look at the bottom of the screen for a thin circuit board with cables coming from it and make sure the cables a plugged in properly.
If you need anymore help or advice please post back.
Good luck.
Aug 18, 2009 | Acer Aspire 5315 Notebook
When i turn on the vacuum it shuts right off. the speckled bag light is on (2 lights under the plug light)
Im going to guess you have an Electrolux Tank. the control valve inside probably went bad. normally i just disconnect it. Do no try to take it apart if you don't know what your doing. take it to a vacuum shop.
May 24, 2009 | Electrolux Vacuums
Olevia 32" Video question
if unit is still under warranty, utilize it. otherwise your y-sus bd is failing. the problem will get worse. hope this helps.
Feb 18, 2008 | Olevia LT32HVM 32 in. LCD Television
InFocus
Hi there
That is a definate Mainboard replacement.
Must warn you that it could turn out to be a expensive exercise
Feb 06, 2008 | InFocus ScreenPlay 4805 Multimedia...
RAZR V3c Screen Problem
u r phone`s have problem in display cunection check cunection streep, when it little break it gives problem like this replase this cunection or replase display
Aug 10, 2007 | Motorola Mobility RAZR V3
'Speckled' Printing
Do you have the owners manual? Did you cancel the document from the computer and turn the printer off for at least 30 secs. The speckled print and lines are usually caused by a defective toner or worn drum. Usually a drum will last for 10 thousand or more cycles. But sometimes prematurely wear out. Make sure you are absolutely using a genuine Brother OEM supply. Generics have a high failure rate. This is not a heavy duty printer. When you need a drum and toner together, it will be just as cheap to buy another low end Brother printer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Mar 30, 2007 | Brother HL-2040 Laser Printer
Motorola Mobility RAZR V3 Logo
82 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
