Question about Pioneer AVH-P6500DVD Car DVD Player
Camry shudders and quivers when idle, sometimes dies.
Only after driving fast (65-70 mph) for an extended period of time (20+ minutes), my 1996 Camry will have issues while slowing down/stopping. The engine dies and I have to choke the engine for several seconds, praying that my car starts again so the line of cars behind me doesn't run me over.
When I'm idle, the car shudders and quivers as if it's about to stall (it's an automatic), then usually eventually does. However, if I tap the gas or start moving, the problem is solved. Sometimes I smell the scent of something, but I'm not very familiar with cars so I can't determine what the smell is. It smells similar to gasoline, maybe.
    Sergeant:
  • 227 Answers
Have you had your fuel filter changed? If it is clogged it will take more pressure to operate properly so when you give it gas and it runs better might be an indication it needs to be changed. If you are getting too much gas might be flooding and the computer needs to be checked. But when you said it runs better when you give it gas I would think fuel filter.
Posted on Jan 15, 2009
How to recycle cmputer after reseting CEL
1.let car sit overnight. 2. Start engine, put A/C on high, let it idle for 20-25 minutes, 2, then drive car uninterrupted for 60mph for 10 minutes, 3. slow down to 25 mph for 4 minutes, come to a complete stop with foot on brake let it idle for 2 minutes, 4. drive again at 30 mph for 8 minutes, come to a complete stop let it idle with foot on brake for 3 minutes. 4. Drive at 40 mph (turn off overdrive) for 6 minutes. 5. Drive at 20mph for 3 minutes at a time, each time coming to a complete stop with foot on brake for 2 minutes. Do this 4 times. Let the car cool overnight and repeat entire process. Then check status of systems with a code scanner.
Apr 15, 2014 | Toyota Camry Cars & Trucks
1996 lincoln town car 4.6 fast idle in park and in drive idles to 10 mph
Did you check the airflow sensor? Clean it, maybe it will help
Mar 15, 2013 | Cars & Trucks
I have a 1999 grand jeep it cut off when im
I just had this problem on my 1996 Jeep Grand Cherokee. Once the engine got warm, after about 15 to 20 minutes, the car would just die at random times, sometimes when doing 40 mph and sometimes at idle.
I ended up changing the Crankshaft Position Sensor and it cleared the issue.
ebraunston@yahoo.com
Mar 22, 2010 | 1999 Jeep Grand Cherokee
Engine is missing and shaking bad when idleing or driving slow
MY CHECVY ASTRO 92 ,,STARTS FINE IT JUST SHAKES WHEN IN IDLES IN DRIVE OR REVERSE..HAVE NEW WIRES AND DISTIBUTOR
Mar 28, 2009 | 1990 Chevrolet Astro Extended
1995 pontiac bonneville stalls
I just went through lots of troubleshooting and expense on my 1996. Whenever I would lift my foot off the accelerator and was below about 30 mph, the rpm's would starts jumping around and sometimes it would stall. If I gave it a little gas (accelerator), I could sometimes keep it running. It also backfired once in a while. Starts right back up. Also, if I let it idle while in part, it would die after 1-2 minutes.
I ended up finding a hole in the fuel regulator. About a ~$70 part if you get an AC Delco, but very simple to change.
Nov 27, 2008 | 1995 Pontiac Bonneville
97 Camry V6 shudders intermittently
check the engine mounts and drive shafts for play in them. think on that year it may have a balance weight on a drive shaft check this is not lose, these can cause intermittent vibrations or shudders.
Jun 28, 2017 | 1997 Toyota Camry
Pioneer AVH-P6500DVD Car DVD Player Logo
277 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
