Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Problem for Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA,...
Low capacity problem
By desire_harya on Jan 15, 2009
Hi !! I have 500GB HDD installed on my desktop..but when I connect it on the computer it shows 464GB only..even at the time of FORMAT of HDD..it showed the same space
Same Problem
Jan 22, 2009
-   I have the same problem too, is it like that when we all buy it? I'm from Malaysia.. -   jasonleecj
Best Solution
posted on Feb 12, 2009
Very Helpful)
worldvet
Rank: Guru
Rating: 91%, 834 votes
Mostly this is affected by match used to construct the drive geometry. The narrative below is courtesy Tiger Direct of Canada and is their copyrighted content.
When we ask our customers if an Answer is satisfactory, the requested rating is four diamonds for a thorough answer. Hopefully, you will find the below content achieves that mark.
  1. The way size is calculated and displayed.
  2. Any "Partitions" on the disk will change the total in a specific partition.
  3. Hidden files and folders decrease available space.
  4. Compression increases the apparent size, but not the physical size.
  5. Drives larger than the OS or Drivers natively supports.
First, the definition of a megabytes (or gigabytes) is a unit of data storage capacity measured in 1,048,576 bytes (or 1024KB). The larger the numbers, the more apparent the size difference will be when listing the size as megabytes (or gigabytes) versus bytes. Actually, both numbers are correct. The noticeable difference is due to the 1024KB definition of a megabyte. This is why a 95.3GB hard drive can also be listed as having 102 billion bytes of total space. Just think of it as "round off" In the screen shot at right: The first number is the total number of bytes, the second number is based on the number of megabytes or gigabytes.
Second, some computers have a non-DOS hard drive partition that is used for features such as Save to Disk, Hibernation, or Recovery. This partition is not normally reported by the operating system, although it can be viewed using a disk partition utility. This is very common on desktops and laptops. NOTE: Partition information will be created or formatted automatically during initial system setup and a system recovery.
Third, by default, all system files are hidden and cannot be seen. This may adversely affect the reporting of available hard drive space. You can set your Folder Options so you view system and hidden files and folders, but do be careful as changes to system files can adversely affect your system.
Fourth, if you turn on Compression for a drive, it will increase reported free space and used space, but since compression is based upon the actual contents, this number is not fixed, but will change as files are added or changed.
Fifth, older operating systems did not support some of today's larger drives, so the total space reported may be much smaller than the drive specifications.
It is also worth noting that bad sectors are corrected by your operating system and can change the total drive space, free space, or used space as well.
So as long as a drive is reporting a value approximately close to the specification value, you can be comfortable that you received the right drive and that you are getting to correct data storage. Of course, tuning of your drive's partitions and options can yield optimal values, but this is not something for the average user to explore.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 02, 2009
Not Rated)
iCe_sPeRm
Rank: Apprentice
Rating: 0%, 0 votes
hi there....
I always figure .93% of the drive manufacturers rated capacity is what you'll have after formating the drive
because advertising a drives larger size is just a marketing gimmick. a drive advertised as 1TB or the same
drive advertised as 930GB remember advertised size sells the bigger the better.
120GB x .93% = 111GB
250GB x .93% = 232GB
300GB x .93% = 279GB
500GB x .93% = 465GB
750GB x .93% = 697GB
1000GB or 1 TB x .93% = 930GB
hope that would help... cheerz!
Was this helpful?
Yes
No
Solution #3
Not Rated)
SHOGUN125
Rank: Wiz
Rating: 82%, 36 votes
hi..there...nothing to worry about it..why?? because hard drive (HDD) need a little space to keep their system program that make it work and detect by your computer.
same thing if you buy HDD with 160GB you will not get pure 160GB but less than 160GB maybe around 154GB ,cause they keep a little space for their system...
Was this helpful?
Yes
No
Popular Solutions for Seagate FreeAgent Pro - 500GB,
Questions and Unsolved Problems for Seagate FreeAgent Pro - 500GB,
Do you recommend Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive?
Answer
Answer
i dropped my Seagate Freeagent 1.5 TB drive and now my Mac won't recognize it.
Answer
I have a 500GB External HDD (Seagate made in china). I need a driver for it.
Answer
my seagate hard drive comes on but my mac cannot mount the drive
Answer
back up on seagate 500gb failed, log file shows error codes 2013
Answer
Hi, each time I reboot Vista 32bit, its like the computer doesn't remember it, the settings have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drives Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
