Question about Hobart Handler 140 Mig Welder
Wire feeds too quickly
I have an Hobart Handler 125 EZ Welder and I'm having a problem with it feeding the wire too quickly. Is there any way to adjust the speed?
Thank you,
Mike
    President:
  • 2,976 Answers
Some welders control wire speed with the amps control, some control amps with the wire speed control. You might try turning things up until it runs smoothly without pushing back. If you're new at welding, it does take some practice until it feels right.
Posted on Jan 23, 2009
I have not used a wire welder very much. A friend encouraged me to try the one he had. I ran it out of wire before welding hardly any and when I tried to put the new spool in I could not get it to feed...
you may need a gun liner, if the liner is kinked the wire will not feed, causing a "birdnest" and if the wadded up wire touches the cabinet while the trigger is keyed it will get hot and try to weld wherever it is grounding e.g. the cabinet. try a liner first they are only 20 bucks
Aug 22, 2011 | Hobart Handler 125 Ez
Wire does not feed but you can hear a click inside the welder when you press the trigger.
Does the feed wheel move? If so adjust it's tension on the wire. If not, check for voltage at the motor. If there is voltage and no rotation, check for continuity of the winding, there should be less than 5000 ohms. If no continuity replace motor. If continuity- oil the shaft with light motor oil and see if it releases.
If no voltage is measured at motor connections, the fault is on the speed control board. check the fuse, and if that is okay, check the SCR(s) and replace if faulty.
Feb 18, 2011 | Hobart Handler 125 Ez
Welder pulsates
Hello, by pulsates, do you mean that the wire feed is what is pulsating while welding? If so, I have had this as well. I found that by turning down my feed rate, the pulsing stopped and the feed was smooth. I hope this helps. If not, contact me again.
joe
Jan 08, 2011 | Hobart Handler 125 Ez
Installed new spool wire tangled in wire feed compartment and stopped. Now wire feeder doesn't feed.
If the feed wheel mechanism does not move, check for voltage at the motor. If there is none present, you need to look for a failure on the control board, which may be a fuse, or even one of the SCR's. Often an 8 amp 200 volt type.
Jun 27, 2010 | Hobart Handler 125 Ez
Need to try and find a wire feed motor for Hobart 120 Handler.Mine is smoking.I think its a 1997. Thanks
go to praxair ,air gas s j smith or any welding shop they can get it for you,
Mar 16, 2010 | Hobart Handler 125 Ez
Wire doesn't feed and I cannot get an arc
Fist look and check the contact tip. ensure the tip is the correct size for the wire being used as well as the wire feed rollers. the contact tip is were the wire collects the power,
If it's only 3 day's old send it back, dont star strippin it down or you Garantee will be made invalid.
ken
Jan 09, 2010 | Hobart Handler 125 Ez
Sporatic wire feed not smooth wire seems to be jumpy
This has happened to me when I tightened the wire spool too tight in the welder,or I had a bad tip that caused some binding,and once my cord had a small kink that damage my wirefeed cord I had to replace.
Jul 12, 2009 | Hobart Handler 125 Ez
Hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
Feb 13, 2009 | Hobart Handler 140 Mig Welder
Trying to weld with Hobart 125 EZ
If you are using flux wire and not shielding gas, your clamp should be positive and the wire should be negative. Heat is provided by the electrical arc that happens between the wire and the material. Your welder by itself does not pre heat the material and with 3/16 material you should not need to preheat anyway.
The electrical arc is kept consistent by adjusting the wire feed rate and the current applied. You will need to experiment with these settings to find what works best with your welder. For this welder and 3/16 material, I would suggest you start at the upper end of the current scale and about a third of the way up on wire speed. The welder might have a chart for these settings in the manual or inside cover.
If the wire feeds too fast, it will push the probe around and you will feel pressure as the wire feeds out. If the speed is too slow you will get large spatters and intermittent arcs. When properly adjusted the arc will sound even and consistent. The arc gap should always be about 1/8 of an inch.
To maintain enough heat for good penatration, do not move the probe too fast, work in a pattern and watch the weld pool (melted metal) and not the arc. Watching the weld pool will clue you in if you are moving too fast or too slow.
I hope this helps.
-Scott
Feb 03, 2009 | Hobart Handler 125 Ez
Hobart Handler 140 Mig Welder Logo
547 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
oneStan
oneStan
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
