Question about Acer Aspire 5315 Notebook
Laptop hang problem
When i m start the laptop after ten to fifteen minute the laptop is hang when i m restart my laptop i m lose total work
  • 114 Answers
Could be a bad battery. Try running it on AC with the battery removed. If it works, you might need a new battery.
If that doesn't work, sounds like dust and dirt has clogged the inside which causes it to overheat and shutdown. Someone will need to take it apart and clean it.
Posted on Jan 15, 2009
WONT RESTART AFTER SHORT TRIPS AND ENGINE HEATS TO NORMAL
If you can duplicate the event in your driveway, you can check fuel pressure and spark at the plugs when it won't start to narrow down the possible causes.
Mar 07, 2013 | 1998 Land Rover Range Rover
How long does a handball match last?
The total playtime length of a game is 60 minutes. There are two 30 minute halves with a ten to fifteen minute break in between.
Jan 14, 2013 | Sport & Outdoor - Others
My car anti-theft seems to have kicked in and I can't get it to start. What do I do next?
hi, you can perform the reset with just your key and a battery charger to see if this will allow for restart. what you do is, hook up a battery charger to start with, low amperage setting like 15 amp, or maybe 2 amp, and leave it on the battery, you will be leaving the key on for up to an hour and the battery must not die during this time. turn the key on and try to start once for about 1-2 seconds, then let go and let key rest in run position for fifteen minutes at minimum. then turn off the key, wait ten seconds, and turn on again to run position only, leave on for another fifiteen minutes, then again, turn off for ten seconds, turn back on to run position for fifteen minutes. after this time, turn the key off, wait ten seconds, and try to start the car. if it starts, check to see if the check engine light is illuminated, or the security light is on, if one or the other is on, take to a shop and have codes checked and diagnosed, if no lights on, you should be able to drive on. if the vehicle does not start after three reset key cycles, try the process one more time. it may have been interupted somehow. if you try twice and still no start, you have to have diagnosed further, maybe in the key, maybe in the lock cylinder, maybe in the theft module.
Jun 30, 2010 | 2000 Buick Regal
2006 Chevrolet Equinox won't start, security system is engaged, how do we restart it?
Make sure the doors and trunk,and hood are shut,open them,and shut them .activate the anti theft,wait about 1 minute,and disarm it,see if it will start,if not,the key fob may need to be relearned,try turning the key on,leave it ten minutes,then turn it off,and right back on,then wait ten minutes,and turn it off,and right back on,do this a total of three times,,30 minutes,then try and start.
Apr 21, 2010 | 2006 Chevrolet Equinox
Truck wont start
Turn the key on and leave it on for ten minutes,then turn it off,and right back on,leave it on for ten minutes,then turn it off,and right back on for ten minutes,a total of three times,30 minutes.Then try and start the vehicle.
Apr 11, 2010 | 1999 Ford F350 Regular Cab
My mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a...
my mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a bit. Any suggestions?
Nov 17, 2009 | Mr. Heater MH9B Ceramic Utility
My Toshiba Satellite PC hangs when I insert any USB device
To reinstall USB drivers, you need to reinstall the system, as USB root hub drivers are built in on Windows.
Tray first removing laptop battery and unplugging AC charger for ten or fifteen minutes, this will get rid of static charges that can cause USB not to work.
If that does not solve the problem then you need to reinstall Windows, in this case, try a system restore first.
If all that still does not work, then there is an hardware fault, in that case you often need to replace the motherboard.
Jan 02, 2009 | Toshiba Satellite A105 Notebook
Nocking motor
the motor starts nocking after about ten to fifteen minutes of running.and looks like it is overheating but i do not understand the overheating signals on the dashboard.
Jul 23, 2008 | 2001 Dodge Intrepid
Acer Aspire 5315 Notebook Logo
85 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
