Compatibility Is the Belkin Wireless G All-in-0ne Print Server compatible with a HP2355 Printer Please
  • grahamwillmo Jan 15, 2009
    Thanks for the resonse. I had seen on the web that there was a Bekin dedicated list that specifically stated whether a Printer, in this case a HP2355, was compatible or not. So the response does not confirm in the specific.
    Thanks for the advice. I have purchased the Print Server, lets see how I get on when I install the Unit.
  • 837 Answers
I have yet to setup any printer on a print server and not have it work. There are times that some functions do not work. For example there are control buttons on the printer itself for scanning, copying, faxing etc that if it was "directly" connected to the computer itself the computer would prompt you .. those kind of things don't work .. but other than that .. You should have no problem
Posted on Jan 15, 2009
  • Jay Glendenning
    Jay Glendenning Jan 15, 2009
    The process of installation is probably based on installing with the printer attached to the PC. What I do to "work around" is do that process.
    When complete I setup the wireless print server.
    I then attach the printer (in your case HP2355) and then setup the printer on the print server using its software.
    The Belkin people know that the HP needs to be connected for installation but once you have software on your PC .. all you are doing is changing the port it is attached to.
How to make a printer wireless
Plug into a wireless print server.If your printer has a USB port, you can plug in a wireless print server, a small box into which you can connect your printer. The advantage of investing in a print server is that you don't have to connect the printer to a PC, which means you can use your laptop and print anywhere in your home.
.tmnAdsenseContainer{margin-bottom:10px;} We found plenty of print servers in the $50 range on, although many of the models cost closer to $75 or $100). Before you buy, make sure the print server is compatible with your printer (the printer's written materials are less likely to specify compatibility with print servers).
During the setup, you will have to plug the printer into the printer server, and connect that to the router using an Ethernet cable. Meanwhile, you'll have to install software on your computer and configure the connection, as you would when setting up a router.
also try this link will help you
Dec 27, 2012 | Samsung Office Equipment & Supplies
Can I wirelessly network my hp pec 1350 with a belkin wireless g all in one print server
The Belkin Wireless G All-In-One Print Server lets you easily add an all-in-one printer to your wireless or wired network. It features 802.11g technology that makes sending print jobs faster than ever, and includes a memory buffer that handles your graphic jobs effortlessly. The Print Server is so easy to install that you'll be printing in minutes. Simply connect your Print Server to your Belkin Wireless Router and run the Belkin Easy Installation CD. Next, attach your USB printer to the Print Server and load yourprinter drivers onto your computer. You are now free to print, scan, fax and readcard media* wirelessly from around the home or office. The Print Server also works flawlessly with wired networks through its integrated Ethernet port. Compatible with most USB, network-ready printers, the Wireless G All-In-One Print Server from Belkin delivers even your most data-intensive print jobs with maximum speed and reliability.
*If your all-in-one device has a card-reader slot.
Nov 21, 2012 | HP Psc 1350 All In One Printer Scanner...
Plz hlp me how 2 setup Samsung SCX-4521F All-In-One Laser Printer Connect router ( wirless)
The device has only a USB connectivity. It cannot be connected to router. You can however connect thru a wireless print server (check the compatibility of the print server with your printer before you buy one).
Feb 16, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Re-set of wireless g print server
With this print server not all printer are compatible with it, but if you connect same model of printer that was also working with this print server, best thing to do here again is to reset the router and reconfigure it back using the setup CD that came with it and if still the same problem, it will be better to call Linksys tech support so they can check if your printer is compatible with this print server if its compatible let one of the Linksys tech walk you through with the process, they are open 24/7 this is the number 800-3267114....
Hope that helps...........
Sep 21, 2008 | Linksys Wireless-G WPS54G Print Server
D-Link DP-301U Problem
It should be fine as long as it is in the range that the router can recognize and that it doesn't conflict with another IP address used on another device. Usually on the networks I design I keep the printers on higher IP address so that they can be managed on a certain range.
Is this the wireless print server?
What specifically do you mean by PJL printer block?
Aug 04, 2008 | D-Link DP 301U (DP-301U) Print Server
D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Jan 27, 2008 | Sharp AR-5320 Black and White Copier
Belkin all in one print server can't configure
make sure the printer is listed as a network printer...add a printer then check the box for network printer. then click browse and click the printer with the name of the printer you are using
Sep 18, 2007 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
