Question about Smeg UK2010X-1 Pyrolytic Stainless Steel Electric Single Oven
Error codes for Smeg S2010MXF5 Pyrolytic Stainless Steel Oven
I have 2 problems: The first is that last night the oven started beeping at me with code F8 ER - I had used it to cook a pizza and had just switched the controls to "off". There are no error codes in my manual and can't find any on the internet - are you able to advise what this error codes means? The second is that the oven cooks unevenly across the cooker it is much hotter on the right hand side (and can burn things) even when using the fan. I have recently had the circular element at the back of the cooker replaced, though I understand that there is more than 1 element in this cooker - could it be another element has died? The inside of the door has also been replaced at the same time as the element (as the enamel was slightly chipped)plus the clock and buttons (three of the buttons had come adrift the clock had worked fine). Typical Italian manufacture beautiful to look at but unreliable?
4 Suggested Answers
SOURCE:
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
barkencoa
  • 3463 Answers
SOURCE: Smeg oven not working
You have a element and or a faulty thermostat
Posted on Nov 25, 2008
kachbibi1
  • 979 Answers
SOURCE: smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Posted on Feb 11, 2009
Circuit board failure
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Mar 24, 2011 | Smeg F170 Pyrolytic Stainless Steel...
I have a Smeg SA130P single oven. I have run a self-cleaning cycle. The cycle completed but, some hours later the lock indicator is still on and the door is locked. How do I get it unlocked?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 13, 2010 | Smeg F170 Pyrolytic Stainless Steel...
Lots of water/condensate ends up on bottom of oven
I have the same problem with my new Smeg oven. I try to avoid using the oven at the moment because of the amount of condensation I have to mop up each time I use it, even the floor get wet!. Smeg have said they will replace it but I am now looking for an oven that will fit into the 'whole' the oven will leave in my newly renovated kitchen. I wish I had never ventured near to SMEG. I would never recomend Smeg to friends, quite the opposite.
Jan 19, 2010 | Smeg F170 Pyrolytic Stainless Steel...
Pyrolytic cleaning won't start. Neff B15P42.0 GB
you have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
Sep 10, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
May 01, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
Smeg UK2010X-1 Pyrolytic Stainless Steel Electric Single Oven Logo
244 people viewed this question
Top Smeg Ovens Experts
Jason Harris
Jason Harris
svoorhees
Level 1 Expert
Are you a Smeg Oven Expert? Answer questions, earn points and help others
