Question about Hitachi 42HDS69 42 in. Plasma Television
Sinotec tv, went out after power serge
i have a Sinotec TV that went off and stayed off after a power serge, i used a multimetre and all parts are are giving me readings, what should i check for???
  • pragasen_nai Jan 16, 2009
    i can i email you pic of the board, email me and i will reply,
    playa120@gmail.com
  • Brian mulenga May 07, 2013
    I also have the same problem what can I do,power went and when it came back it is just showing red on the stand
I'm having the same problem,my sinotec will not go on at all!!! I want to fix it personally without going to a technician:C
Posted on May 09, 2012
    Sergeant:
  • 227 Answers
Do you have power to the tv? When you say all parts are giving you a reading what parts? Need to check Fusistor looks like a rectangle sand stone that will have 5 or 10 ohm markings on it. Next check rectifiers, look like resistors except black w/band on one end. Should only read in one direction if it reads the same on both sides probably bad. When I say read on one side You will take your multimeter on ohms and put positive one side and negative on the other take note of ohm reading, then reverse the leads and see what that reading is. If same it is bad.
Posted on Jan 15, 2009
Our Sinotec T.V. Went into a deep sleep. What do we do?
Main power supply regulator board (SMPS board) inside the TV is faulty. Check and replace it. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Jan 11, 2017 | Televison & Video
Samsung curve 65 inch has no sound, has picture.. Using Bluetooth curved sound bar, no sound on tv speakers either
Hi!
Check your power amp circuit. Or, check if it is feed by the power supply circuit. Good luck,
Serge.
Oct 09, 2016 | Samsung UN65HU8700 65"" Curved 4K Ultra HD...
Sinotec lcd tv troubleshooting
Check this link to get some details about servicing Sinotec TVs. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 04, 2013 | Televison & Video
Hi, while i was watching my Sinotec TV, it just switched off by itself. For a moment i thought it was the power that tripped but i was wrong. I tried to plug it on different endpoints but still not...
Yes, Look up your TV Model Number, then youtube assembly and disassembly instructions to replace LCD Inverter and/or Power inverter.
On Flat panel televisions its usually a standard power inverter, sometimes smaller LCD inverters though.
a relatively cheap replacement part and a job you could do yourself to save yourself a few hundred dollars.
Feb 28, 2011 | Televison & Video
SONY DVD REMOTE CODE FOR SINOTEC LCD
I just followed the instructions to program the Samsung remote (Press tv button then press and hold the power button whilst pointing at your TV and type in the code) ....I went through every code until my TV turned off....The code for my Sinotec is 75
Jun 14, 2009 | Samsung TXM3296HF 32" TV
Power serge
ok First question does the led continue to blink after 70 seconds after u plug it in. it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature. Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set
Jan 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sinotec 37cm tv
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the music button for about 10 seconds. This worked for me.
Oct 05, 2007 | Televison & Video
No power after Lightning Storm
If you have homeowners insurance and can file a claim on it, perhaps your insurance adjuster knows of a shop that could handle this problem. Most likely you will be needing the power board replaced, p/n 8667200700T unless it can be repaired. The schematic for this set is not listed as an available part for this set (In the future it would be very wise to stay away from any manufacturer that does not support what they make). After restoring power to the set, you could find that there are other problems such as a defective tuner or audio/video problems due to the power surge. It may be possible to fix the power supply without a schematic if that is the only part that has been damaged.
Dec 19, 2006 | Apex Digital GB43HD09 43" Rear Projection...
Hitachi 42HDS69 42 in. Plasma Television Logo
392 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
