Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung HC-P4752W 47 turns its self on and off.
I have a Samsung HC-P4752W 47 rear projection TV. I changed some settings in the service menu which has caused this unit to keep on turning itself on and off every five to ten seconds.
Any ideas as to what could be the cause of this? would you happen to have the recomended factory settings for the service menu?
Please assist
  • kvansloo Feb 24, 2009
    mine does same thing but i replaced sub board and converg module and adjusted converg in grid mode
  • Samsung Master
  • 1,525 Answers
It might be set on sleep mode check again
shaun
Posted on Jan 16, 2009
How do you get into the service menu on Samsung hcp4752w
I dont remember it exactly but ..if your TV is on then Press Standby and then press Info + Enter + Menu + Standby to turn on..you will get the service menu on screen.
Just alter the sequence of info + enter + menu to info + menu + enter or something.
hope it works
regards
bhavin
Apr 06, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" projection TV distortion & yellow?
I think you have a fault on the chroma board and on the picture frame board. If you can trace it yourself try these two locations otherwise call out a competant technician. hope this helps.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
TV problem
It sounds like there is a fault on the chroma panel of some kind.
Jul 23, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47 in. Rear Projection bigscreen TV
You dont have to remove the aluminum heat sink. The ICs are attached with screws and then just unsolder the ICs from the circuit board and then replace the new ics into the pin hole locations after applying heat sink compound onto the back then screww the new ICs to the heat sinks then solder the pins. Very easy repair.
Jun 19, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4752w
Not sure of the part number most use STK392-110 or 120s . You will need to look at the ics in your set they will have the IC numbers stamped on them they will have STKxxx-xxx whatever that number is thats the sanyo part number for those ICs
Mar 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Now What???
I want to get this straight are you saying that you cant align them
and this is your focus problem or you have two problems that you cant get the convergence and the focus?
it might have been easier just to have the board replaced...
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Jan 28, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung SP-52Q7HE
Convergence ic need to be replaced.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 10, 2007 | Samsung HC-P4752W 47" Rear Projection...
Convergence and self focus probs
Need all the facts for research = what board part # was replaced ? cost ? Do you have original board ? Was work done in your presence ? total cost ? Help me so I can help you.....T.
Nov 05, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W Blurry ONLY on HD Channels
Similar problem, then about 2 weeks later the SD convergence went out. Changes convergence Amps,,, Now I'm trying to learn what 2 red flashes mean now when I try to power it up,,, it flashes twice then shut down into standby mode,,, I got no picture after installing STK392-040 chips, thinking about trying another set as atleast I had blury picture before. No solder shorts of opens that I can find. TV has always been a pain,,, locking up once in a while such that you can't change modes,,,
Jul 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
205 people viewed this question
Henry  Thomas
Henry Thomas
