I think the system needs a better graphic driver but it appears the last updated driver is dated 2002. In the middle of using the machine for about an hour the unit "clicks" and a few seconds later the last few mouse motions appear like a jet stream across the screen, then the screen all turns gray, green, white, and black and it's finished. I have to turn the unit off and then back on again. It works great aside from this problem.
SOURCE: gateway 42in plasma p420142v5
try to check the connection of your coax/antenna at the back of your plasma tv. if it presist some of the components inside were damage maybe burnt for excessive use. Try to contact a certified repair man for that issue.
SOURCE: monitor goes black 1 second after coming to full screen
Same problem here. Does anybody have an answer?
SOURCE: Slow start
(I'm copying a guest's comment above. What Gateway told him does seem to work - although in my case, the monitor was slow to start when plugged directly into the wall, and it was immediately fixed when I plugged it back into a heavy duty power bar.)
hey, I had the same problem. Gateway told me "Plug the monitor power plug directly into a wall electrical outlet
or
a different wall outlet by removing any surge suppressors." I did that
and it works. It might be a certain kind of power bar they do not like.
It worked for me so try that and see if that helps.
SOURCE: Gateway profile all in one system shuts itself off
I just had a machine in the other day with the exact problem you describe. Don't know if this will help but they had a worm and when the anti-virus kicked in or they opened any type of online program like a broswer or email the computer would shut down.
Also hardware could be the issue. If its not the above issue could you tell us when the last time the heatsink was cleaned. What if anything your doing when it shuts down....
SOURCE: my screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
To update firmware you will need a Microsoft Windows based PC and download the latest firmware on this website:
http://www.samsungsecurity.com/product/product_view.asp?idx=6404.
SEW-3030_mr8911isp-nor+spi_For US.zip (2.23MB)
Once downloaded, unzip files to your desktop and do the following sequence:
1st -> RUN file Generic_V1.0.0.0.EXE (USB firmware update driver)
2nd -> connect your wireless video monitor to power adapter
3rd -> press and hold select (enter) button in the middle of the dial.
4th -> connect USB cable to your PC. (screen will blank white instead of black) this is firmware update mode
5th -> RUN firmware update utility mr8911isp.exe , wait to USB connection (status bar will turn green) and show message ASIC: 0301 Device Connected
6th -> Press Update button and wait...
7th -> Update done! disconnect your device and voila! no more date/time issues and another bonus bugs fixed noticed: lower alarm beep volume, menu text size increased for better reading, temperature sensor more reliable
I Hope it help everyone having problems with this baby monitor
