Question about Hotpoint Ultima WF860 Front Load Washer
Door lock will not releace
At the end of wash door lock indicator stays on flashing and will not release
  • Anonymous Jan 15, 2009
    tried that didn't work :-( thanks anyway
    any other ideas welcome
    Problem Solver:
  • 30 Answers
Some door locks are powered by a solenoid.
Have you tried unplugging the machine to see if the lock will release then?
Posted on Jan 15, 2009
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
Need instructions
The owner's manual will tell you step by step how to program it. Normally you would follow these steps (with the engine off):
1. Press and hold down the two outsid buttons releasing only when the indicator light begins to flash.
2. Position the end of your hand-held transmitter about 1 to 3 inches away from the buttons while keeping the indicator light in view.
3. Simutaneiously press and hold both the desired button and teh hand-held transmitter button. Do not release the buttons until the indicator light flashes slowly at first and then rapidly. Then releas both buttons.
4. Press and hold the newly-trained button and observe the indicator light. If the indcator light stays on constantly, programming is complete and your garage door should activate when you press the button.
Nov 26, 2013 | Wright Products International VC333BL...
Program garage door to my garage opener in my 2002 yukon Denali
Apr 06, 2013 | Building Materials
Bosch 100 series wont start... lights stay on for wash rinse spin, but door lock doesnt light
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped
Mar 26, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Hotpoint WMA62 washing machine door won't release
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock.
Apr 24, 2012 | Hotpoint WMA64 Front Load Washer
How do i turn the tune off when the load ends
This is an automatic function and the machine will shut down , beep to indicate and release the door .
if this wont happen then the timer controller unit and the door lock /door switch must be checked.
Sep 23, 2011 | Washing Machines
CathI have a dishlex global 510 and I cant open the door does it have a child lock and if so how do I turn it off so as I can open the door
heres what it says in your manual
Follow these steps to set the Button Lock function:
1. Switch on the appliance.
2. Set a washing program.
3. Start the washing program.
4. Press Button Lock for approximately 5 seconds, or
until the Button Lock indicator light flashes.
5. Button Lock indicator light flashes for approximately
15 seconds.
6. When Button Lock function is active the indicator
light is on with a static light.
At the end of a washing program the Button Lock function
is deactivated by opening and closing the door or
switching off the appliance.
Important! It is not possible to deactivate the Button
Lock function while a washing program is in progress
if you have any further questions message me back Thanks Rick
Jun 11, 2011 | Dishwashers
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Washer flashing dl on the screen
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
135 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
