Question about Radio Shack VGA PC Camera Webcam
1995 GMC Yukon Radio says LOC
Got this code from the radio need info on unlocking radio
572-578
  • Liz Morgan Mar 01, 2009
    Bought a used 1997 Yukon . I have all the manuals.....i cannot find the code to unlock it? any suggestions?
    Sergeant:
  • 191 Answers
Press & hold the 2 & 3 buttons @ the same time for about 10 seconds; a 2 or 3 digit code will appear, write this # down,press & hold the am/fm button for about 10 seconds: another code will appear, write this # down, then call 1-800-537-5140 and enter 202108 followed by the * key, then enter the #'s that you wrote down from your radio followed by the * key. The call will give you a 3 or 4 digit override code. Write this code # down so you have it if you ever need it again. Enter this # into your radio following the instructions in your owners manual. If you get an override code that starts with 0, you drop the 0 when entering the code into your radio.
If you don't have an owners manual, try this, press & hold the hour button until the first 2 digits of your code come up, then press & hold the minute button until the last 2 digits show. Then press the am/fm button. This should reset your stereo,
if nothing happens you should leave your car running for 1 hour.
Posted on Apr 19, 2009
  • Dale Long Apr 22, 2009
    if nothing happens you should leave your car running for 1 hour, then repeat the steps again.
How do I unlock a radio when it displays the word LOC on a 1997 GMC Jimmy?
It is written in your owners manual. you need a code which the original owner would have written down somewhere in the manual. If no code, no radio. Only the dealer can unlock and make new code.
Dec 09, 2014 | 1997 GMC Jimmy
What is the radio code for a 1995 GMC Yukon IDENTIFICATION NUMBER 1GKEK13K4SJ757083
Im sorry my friend
this kind of information
You can only get it in only in GMC store
noone else have this access
Nov 26, 2010 | 1995 GMC Yukon
Had a dead battery, it was removed and replaced. Now radio message shows LOC. Please help with a code to unlock the radio and clock, etc.
That code is an anti theft measure, the only way to obtain a radio code legally is to look for it in the car's papers or go to a dealer and they will provide it to you for a small fee - ~ $25.
Aug 09, 2010 | 1995 GMC Sierra C1500
The radio will not work after exchange of the battery in the youkon xl how to fix?
need to notify dealer for code call first they will notify how to retrieve radio id code which will also be needed with proof of ownership and id u can get ur un-loc code
Jun 28, 2010 | 2007 GMC Yukon
I need a radio code to unlock gm part 10356164
Your '05 is too new to unlock on your own.
There are 2 types of GM Theftlock, Theftlock I and Theftlock II. The Theftlock I is found in pre 2000 vehicles, and Theftlock II is in the later models.
Theftlock I - Uses a volatile user settable code that is input through the key pad on the front of the Radio. If the power is lost (dead battery etc.) the code is gone and must be re-entered for the radio to work. But with the correct procedure the owner can unlock it.
Theftlock II - Uses an EPROM (erasable/programmable read only memory) or a PROM (the difference is you can not alter the prom once it is programmed).
In either case the code is burned in and holds even when the power is lost. With Theftlock II the radio is married to the vehicle by way of the VIN. When the vehicle is started the computer compares the number in the radio with the VIN in the body control module. If they match, the radio works, if not the radio displays LOC and you are finished, there is no easy way around it. The radio will not work until you make a trip to the dealer.
The dealer will use a TECH 2 scanner to change the VIN stored in the radio. The radio does not need to be removed (for the serial number or any other nonsense). The technician just plugs into the computer and resets the VIN in the radio.
Thank you for using fixya and keep us posted.
Jul 10, 2010 | 2005 GMC Yukon
2000 GMC Safari, lost power to the vehicle. The radio did disply 'loc' and now displays 'InOP'. Please Help
Hi
Thanks for using FixYa. If you fail to enter the correct code eight (8) times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere).
After that the the radio will go to LOC mode, then follow this procedure to unlock it—
To unlock the car radio - Have a pen and paper ready. Push and hold stereo preset buttons 2 and 3 simultaneously for several seconds. Three digits will appear in the display "XXX", write them down. Push the AM/FM button, three more digits will appear in display "YYY", write them down.
Press 1 then # (pound). You’ll hear “Invalid Code, try again”
Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start)
Enter the six didgit number obtained from above procedure.
Listen to the four-digit number and write it down. It will be repeated twice
Turn the ignition ON (The radio displays LOC)
Use the MN and HR buttons to enter the $ digit code that you have heard.
Press the AM/FM button. The radio display changes to SEC. Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction in Owner’s manual.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 13, 2009 | 2000 GMC Safari
Need code to unlock 1997 Jimmy Radio
the loc code is set the first time the radio is turned on. if you don't know the code there is no legal way to unlock it with out the tools at the dealership.
Aug 14, 2009 | 1998 GMC Jimmy
What is the code to unlock the radio on a 2004 gmc yukon?
look in owners manual ! if u dont have 1 go see dealers service dept.
Apr 07, 2009 | 2004 GMC Yukon
Radio has loc in the display how do i fix rhis
Go to www.DelcoLockCodes.com and they can get the unlock code for your radio.
Oct 29, 2008 | 2005 GMC Sierra
Radio Shack VGA PC Camera Webcam Logo
172 people viewed this question
Top Radio Shack Computers & Internet Experts
Mark Gough
micky dee
Mike
Are you a Radio Shack Computer and Internet Expert? Answer questions, earn points and help others
