Televison & Video Logo
Posted on Apr 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connecting TV to Hi Fi wirelessly
I have a new Sony Brevia TV and would like to connect it to my hi fi system so that all tv transmissions and also DVD's play through my Hi Fi.
I have spare speaker outputs on my Rotel amp and also have an auxilliary input not being used (normally used to connect a Tuner I think)
The trouble is I don't want to have to start pulling up the floor etc again (all cables were routed before I decorated when I instaled the Hi Fi a while back)
Is there such a thing as a wireless device that will connect to the TV and send a signal to another wirelss device connected to the Hi Fi amp?
  • Anonymous Feb 17, 2009
    TV is on the other side of the room as my hi-fi. Don't want phono cables (if I could find any long enough!) trawling all the way around the room to the hi-fi. Wireless must be the answer!
Al Toledo
Level 2:
  • Expert 223 Answers
  • Posted on Apr 18, 2017
Al Toledo
Expert
Level 2:
Answers
223
Questions
0
Helped
148878
Points
476
There are several different wireless receivers that you can consider.
A simple solution would be the following:
Both devices being connected must support the ARC feature. HDMI ports may be marked with ARC to show which one to use. If not, check your product manual or specifications to see if the ARC feature is supported.
If you find that your TV, A/V receiver or home theater system does not support ARC, you will need to use Option 2: Coaxial Digital Cable, Optical Digital Cable, or Audio Cable to connect your devices.
Make sure that both devices support ARC functionality.
Make sure that the TV and receiver are connected using an HDMI cable.
Connect the cable to the HDMI port that is labeled ARC or the port identified in your manual that supports ARC.
Turn on the Control for HDMI setting on both the TV and the receiver or home theater system.
NOTE: The steps required to enable the Control for HDMI feature may vary. Check the operating instructions supplied with the devices for model-specific steps.
connecting TV to Hi Fi wirelessly - sony help-j2q2bwu4vctmzoikui5pyi32-2-0.jpg
1 Related Answer
skotkolr
Scott Hill
  • 558 Answers
  • Posted on Apr 27, 2008
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Can i use wireless speakers with this system
Yes but only if the hi-fi unit either has a built in wireless transmitter or the wireless speakers arrived with a dedicated sender unit to plug into the hi-fi or tv or whatever you need to use them with.
I suggest you begin by reading the two relevant instruction booklets or finding the specifications online.
If there is no sender unit it might be possible to buy a generic wireless sender unit.
Will the above model support Netflix?
Yes, the TV itself does have a Netflix app built-in. Is the TV currently connected to the internet? If not you might have to hardwire it using an ethernet cable or hook up a wireless bridge. See page 13: https://docs.sony.com/release/KDL40Z5100.pdf
One trick is to use a wi-fi range extender/wi-fi booster with ethernet port.
How do i connect my technics sh-dv290 to my tv and what leads do i need
i am trying to do same thing - i suggest connect ps3 via optical cable to hi fi red/ white cables via a optical/ rca adaptor, the ps3 is connected to tv via hdmi so play dvd via ps3 sound will play through hi fi - but remember dont need the yellow dvd cable from hifi dvd player to tv any more as you will be using the ps3 as a dvd player instead
1helpful
I was accidently connected the subwoofer ,when my sony hi-fi volume level is 30 (maximum)...and then it automatically shutdown..after that,it started to show PUSH POWER ,PROTECT..
Hi, I believe the sub is the wrong kind for your system. It should be a selfpowered sub one that you plug in to AC power and then connect to Hi/fi. You could do some damage to your system if you carry on with that. Good luck
3helpful
2answers
Trying to attatche the stereo to the television so it goes through the speakers
Does the Stereo have an RCA type aux imput?
If it does you should be able to connect the TV via that. If the TV has a scart socket, but no audio out sockets you can get various scart boxes that will have RCA audio out sockets on.
The speakers on my tv are done in , how can i get sound through anything else can i us a hi fi system
Your TV must have an adapter for output where you can connect the
cord to the input of your hi-fi system. Yes, you can use it, and control
the sound from your TV and Hi-fi. First, you must set your TV volume
to low position. Then, adjust the volume further at your Hi-fi to a
comfortable level. Let us know thru the e-mail and vote for our solution.
1helpful
2answers
Need Adaptor connect DJ Tech Turntable to Sony Mini Hi Fi MHCRG495
The USB turntable is likely a USB data connection and not a USB audio connection, so you will need to take the audio output from your Mac G4 to your Sony Mini Hi Fi...
You will likely need a stereo mini-plug (3.5mm or 1/8-inch) to stereo RCA plug cable (red and white RCA plugs). This is often referred to as a "stereo Y-cable."
Game video input enabling
Dear krismedia
You should first confirm that Audio/Video output cable from the hifi is connected to the TV , then you should connect the game console to the input section in ur hifi system. And finally see if the TV is in AV mode and also see if the HIFI is detecting in the input mode.
2answers
Original DVD plays black and white
It seems that you have get the color system setting of your Tv wrong. Sony uses the Pal(it's a format for the transmission of signals) color system , so check into your TV's color system settings and change it to pal , if that doesnt work then change it to Ntsc.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
