Question about Neff U1421 Double circotherm Electric Oven
Neff U1421W2GB/02 Double Oven Grill problem
My Grill element and top splash cover dropped from the top of the oven. The screw which holds both in place will not screw into the hole in the oven roof liner because the hole has corroded and I cannot get a screw to hold because of the corrosion.
  • Neff Master
  • 3,463 Answers
There are a couple of solutions to this prob,
You can get some plastic metal and build up the corroded area after cleaning it first, then you can drill a new fixing hole for screw.
The other thing you can do is to cut a small metal plate to fit over bad area, drill and fix it to oven liner, again drill a new fixing hole for element to be secured.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
In the top grill of a neff u142nogb built in oven the heated element and back plate have dropped down and a small self tapping screw and L shaped bracket have fell down bot the self tapper has no suitable...
We have a video how to replace the grill element and a part of the video shows how the element is support with bracket and it might help you
Sep 11, 2011 | Neff Ovens
MY FAN IS ON THERMOSTAT LIGHT ON BUT OVEN NOT WORKING THE GRILL WORKS
You need to replace the oven element, this is located behind a removeable cover at the rear of the oven compartment.
Aug 20, 2010 | Neff U1721 Double circotherm Electric Oven
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
How do you change the grill element ? on a Neff U1421N2GB/05
screw at top of element is for support.. there are either 2 screws at the rear of element bracket holding it or access to behind the rear panel is required as there are 2 nuts holding the grill bracket to rear cavity. please make sure power has been disengaged before attemt to repair..
Dec 21, 2009 | Neff U1421 Double circotherm Electric Oven
We have a hotpoint cooker UY46, our electric tripped the cooker off and , now the nob and grill works but the bottem/main oven is turning on and the fan is circulating but not getting hot ? please help ;(
You need to replace the element. Very easy job remove the back plate from inside the oven (4 screws) and you will see a circular element held in place by one screw in the centre of the fixing plate. Remove the fixing screw then remove two wires and refit new element job done.
Regards Neville
Jul 16, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Mar 19, 2009 | Neff U1452 Double circotherm plus Electric...
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
How do I replace the heating element in Neff U1461N2 main oven?
Switch power off first.
Remove the screws that secure the rear cover in the oven compartment.
There you will see the circular element, undo screws that secure element, slówly withdraw element towards you, disconnect leads, taking care not to lose them behind the aperture., fit leads onto new element, and refit element.
Refit cover and test.
Thanks.
Jan 12, 2009 | Neff U1721 Double circotherm Electric Oven
Unable to remove the fan blade on the neff u1721 oven (too tight)
The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
Thanks.
Jan 11, 2009 | Neff U1721 Double circotherm Electric Oven
Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
Apr 18, 2008 | Neff U1721 Double circotherm Electric Oven
Neff U1421 Double circotherm Electric Oven Logo
328 people viewed this question
Top Neff Ovens Experts
bosch5
paulcarew
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
