Am using P2 which has been upgraded to P3 now but it has stop working due to the changes which occured accidentally on the mother board near the processor's settings
  • chessyang May 11, 2010
    are you talking about the jumpers?
  • Samuel Spell
    Samuel Spell May 11, 2010
    What changes? What type of P3? speed of old and speed of new P2 P3 or the names of chips. please post and I will tell you what to do What type of system or motherboard also.
  • 112 Answers
At first check the mother is support the pentium 3 processor or not. then upgrade the processor.
Posted on Jan 21, 2009
My treadmill not running after 7 seconds diplay shows L5
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It is common to see this error as and L5 error, but it is actually an LS error. The following information will define this error and give you the possible solutions to fix this issue.
LS Error with No Belt Movement on Landice Series Treadmills
LS Error on Landice L-Series Treadmills with No Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. If this error occurs with no belt movement, the causes for the LS or L5 error are:A) Faulty upper display board or faulty relay board
B) Improper speed control wiring
C) Improper motor control wiring
D) Worn or faulty motor brushes
E) Faulty pwm/relay combo board or faulty drive motor
Corrective Action A) Enter Open Loop Speed mode and set treadmill speed to confirm proper line voltage to pwm board and that the green BELTSW light is lit on the relay board. Replace upper display board or relay board if necessary.
B) Inspect speed control wiring and correct wiring if necessary:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
C) Inspect motor control wiring, checking wires from motor to A+ and A-. Correct wiring if necessary.
D) Inspect motor brushes verifying brushes slide freely, are at least 3/8" long, are curved and have no burns or cracks. Also check the brush springs and verify that the brush copper wire is not burned or broken. Replace both motor brushes if necessary.
E) Inspect motor turns and is not seized up or has a broken shaft. Replace motor if necessary. Also verify at least 90VDC present from the black (A+) wire and white (A-) wire from the pwm board to the drive motor. If voltage is present, replace pwm/relay combo board. If no voltage present, replace drive motor.
Details about LS Error on Landice Series Treadmills with Belt Movement
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
Correct speed control wiring if necessary.
Oct 13, 2015 | Exercise & Fitness
What does a P3 code mean? On a Hobart LXI high temp
P3 code refers to the probe near the airgap at the back. It is monitoring the rinse temp. P2 is the booser probe, and P1 is the wash tank. The control board will store error codes, so once changed, you can access the memory and clear it.
Jan 05, 2014 | Dishwashers
? L5 Landice 8700
Upper display lights up;treadbelt moves;speed will not increase;L5 error.
Check speed sensor alignment.
It should be within 1/16" of the flywheel
and parallel to the flywheel.
Is it out of position?
Unplug 3 wire speed sensor connector from
wires.
Any found?
Unplug 12 wire upper harness connector
from relay board. Check for pushed pins or
loose wires. Specifically look at 8 (White)
and 12 (Green).
Any found?
Is speed control wiring OK?
Purple wire from V+ on pwm board to P3 on relay board.
Orange wire from P1 on pwm board to P1 on relay board.
Brown wire from P2 on pwm board to P2 on relay board.
P3 on pwm board has no connection.
Adjust speed sensor:
1.Use 1/2" wrench and loosen
the two lock nuts securing
sensor to it's bracket.
2. Adjust sensor gap to 1/16".
3. Tighten lock nuts.
sensor / harness assembly.
Part# 71007
Repair or replace upper
harness. Part# 70251
Correct speed
control wiring.
Replace the speed sensor.
Part # 71007
Feb 05, 2010 | Exercise & Fitness
HP Compaq 5311SR Desktop with XP. I changed the
THERE IS ONLY TOW WAYS TO TIE A POWER SUPPLY TO THE MOTHER BOARD BOTH ARE PLUG
INS TO THE BOARD
Jan 06, 2010 | Computers & Internet
My cd dvd player stopped working? pc says working fine?
try switching the power cable attached to the cd / dvd player..it will have a code on (P1, P2, P3...) swap it with 1 that is not in use...change ribbon cable dats attached from the cd/dvd palyer to motherboard...do not place your hand on the motherboard. if these dont work buy a new cd / dvd player...
Dec 08, 2009 | Gateway Computers & Internet
UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Using an extra connected motherboard as a backplane
BASED ON INFO FURNISHED 'NO',you need the BIOS to activate board systems
Jun 21, 2008 | Computers & Internet
Processor up grade
The fastest cpu you can use on your mb is a pentium 3 800. Providing that you have the latest bios update.
check this link here.
You may need to download and install bios update from factory website .
Feb 22, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Upgrading hard disk
yes of course it will handle a 40gb hard drive..your P3 will handle a hard disk up to 60gb...coz i have a friend, his using a P3-700MHz,512mb, 64mb video card and barracuda 80gb hard disk=.)..to make it sure..bring your P3 to the computer shop so you can also know if your P3 is handle a 40-60gb hard drive..thanks..
Feb 20, 2008 | Dell OPTIPLEX GX1 PIII-550MHz 128MB 10GB...
How to upgrade my processor from p3 to core2 duo
well if your processor is p3 then the motherboard is old enought to suppor C2D.... thus you need to upgrade you mother board
Dec 15, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
297 people viewed this question
David Payne
David Payne
