Question about Intel Motherboard
DJ's Instrument Which is DJ's instrument and what is the uses? And also i want the picture.
  • May 11, 2010
    Can you be a little clearer with your question? I'm afraid I don't have a clue what you are asking about.
  • 1,602 Answers
ITS IN THE WINDOW MOVIE MAKING SOFTWARE THE COMPLETE WINDOW MEDIA CENTER, SYSTEM AND PERFORMANCE SECTION OR WHERE YOU SET UP EVERYTHING , WHAT TO DO WHEN YOU PUT DVD IN OR CR ROM, THE PLAY IT SELF WHAT FUNCTION DO YOU WHAT THE WINDOWS SOFTWARE OR THE ONE YOU BOUGHT AT THE STORE TO SOMETHING THAT LOOKS AND EASY TO USE VERSES THE ONE WINDOWS GIVES YOU.
THE SETTING OF THAT EQUIPMENT IS THE BEST PLACE TO START OR THE MOVIE EDITOR OR MOVIE MAKER, WHATEVER YOU HAVE DONE TO CAUSE YOU THIS ERROR.
OR
DELETE ANY NEW SOFTWARE AND RE INSTALL IT AND USE THE INSTALL NEW SOFTWARE IN THE CONTROL PANAL SO YOU DONT HAVE THESE CONFLICK EVERY TIME YOU NEED TO PLAY ON THE COMPUTER
ROD
Posted on Feb 12, 2009
On a2000buick century odometer not working
You would need to take it to the dealer or someother qualified repair shop that has the diagnostic tool to check for DTC'S - diagnostic trouble codes in the instrument cluster .
DTC B0570 Season Odometer Malfunction
The instrument cluster receives a vehicle speed input from the vehicle speed sensor (VSS) over the Class 2 line. This signal is used in order to drive the speedometer and the odometer of the instrument cluster. The instrument cluster will compare the VSS data with a 16-point look-up table in order to determine needle deflection. A smooth filter is used in order to secure a continuous response. The season odometer displays the total accumulated kilometers (miles) of the vehicle. This value is permanently stored in the Electronically Erasable Programmable Read Only Memory (EEPROM) of the instrument cluster. The trip odometer displays the accumulated kilometers (miles) to the tenths of a kilometer (mile) since the last reset. This value is stored in Keep Alive Memory (KAM) of the instrument cluster.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
Always perform the Instrument Cluster Diagnostic System Check before attempting to diagnose this DTC.
This diagnostic procedure requires using a scan tool.
This repair procedure requires instrument cluster replacement.
Step
Action
Value(s)
Yes
No
Did you perform the Instrument Cluster Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Instrument Cluster
Using a scan tool, clear the instrument cluster DTC and retest for DTC B0570.
Does DTC B0570 reset?
Go to Step 3
Go to Powertrain On Board Diagnostic (OBD) System Check in Engine Controls - 3.1L or Powertrain On Board Diagnostic (OBD) System Check in Engine Controls - 3.8L
Replace the instrument cluster. Refer to Instrument Cluster Replacement .
Is the repair complete?
System OK
© 2017 General Motors Corporation. All rights reserved.
Feb 27, 2017 | 2000 Buick Century
Vacumm diagrams for buick century
There is usually a black plastic tube coming out of the firewall that goes to the manifold. If that looks good, I recommend you access the back of the control panel. From there, you can see if vacuum is getting to the panel and if it is being transferred to the various actuator lines as the mode selector is switched. I have pasted the procedure below.
Buick Models
CAUTION
Vehicles covered by this guide are equipped with a Supplemental Inflatable Restraint (SIR) system, which uses an air bag. Whenever working near any of the SIR components, such as air bag module, steering column and instrument panel, disable the SIR.
Fig. Heater & A/C control panel removal. Top: Standard system; Bottom: Automatic System-1997 Buick shown, others similar
  1. Disconnect the negative battery cable.
  2. Remove the instrument cluster trim plate, using the following as a guide:
    1. Remove the instrument panel access hole covers from the instrument panel using a small flat-bladed tool. Remove the screws from each end of the instrument panel cluster trim plate.
    2. Remove the screws from the lower edge of the right lower instrument panel trim plate.
    3. Open the instrument panel compartment door.
    4. Pull the right lower instrument panel trim plate from the instrument panel.
    5. Pull steering column tilt level and tilt the steering column to the lowest position.
    6. Grasp the instrument panel cluster trim plate at the right edge, slowly pull an working from left to right, release the retainer clips. Lift the trim panel from the vehicle.
  3. Remove the screws holding the heater & A/C control panel to the instrument panel and gently pull the assembly from the instrument panel. Detach the electrical connector(s) from the back of the panel. Some models may have a vacuum line connection that must also be removed.
  4. Installation is the reverse of the removal process. Use care to make sure the retaining clips are properly seated and all screws are in place. This helps avoid rattles and squeaks later.
Jul 21, 2017 | 1997 Buick Century
Gem module
The GEM has nothing to do with it !
Odometer/Trip Odometer
The odometer and trip odometer are displayed in the integrated circuit LCD display. The instrument cluster records the total mileage of the vehicle using information received from the PCM, and electronically displays this information in the LCD. If this information is not received, the LCD displays all dashes. How did you prove that instrument cluster isn't bad ?
Did you have a factory scan tool hooked up , check for DTC'S - diagnostic trouble code's ? View data to the instrument cluster etc...
Instrument Cluster Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1202 Fuel Sender Circuit Open Instrument cluster Go To Pinpoint Test B . B1204 Fuel Sender Circuit Short to Ground Instrument cluster Go To Pinpoint Test B . B1205 EIC Switch-1 Assembly Circuit Failure Instrument cluster INSTALL a new instrument cluster. REFER to Instrument Cluster in this section. TEST the system for normal operation. B1342 Instrument Cluster Is Defective Instrument cluster CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is present, INSTALL a new instrument cluster. REFER to Instrument Cluster in this section. TEST the system for normal operation. B1359 Ignition Run/ACC Circuit Failure Instrument cluster Go To Pinpoint Test A . B1317 Battery Voltage High Instrument cluster Go To Pinpoint Test N . B1318 Battery Voltage Low Instrument cluster Go To Pinpoint Test N . U2199 Invalid Data for Engine Coolant Instrument cluster Go To Pinpoint Test D .
Your best bet ,take it to a qualified repair shop.
  • The speedometer/odometer is inoperative
  • Powertrain control module (PCM).
  • Instrument cluster.
  • Go To Pinpoint Test F .
Dec 04, 2017 | 2005 Ford Focus
Removing the heater control switch 2004 Pontiac Grand Prix
Procedure for the control panel pasted below. I don't see a separate blower switch, so you might have to replace the entire control panel. Before doing that, I recommend you browse this post:
http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow and let me know if you have questions.
CAUTION Vehicles covered by this manual are equipped with a Supplemental Inflatable Restraint (SIR) system, which uses an air bag. Whenever working near any of the SIR components, such as air bag module, steering column and instrument panel, disable the SIR.
Fig. Instrument panel accessory trim plate removal-Pontiac shown, others similar
Fig. Heater & A/C control panel removal. Top: Standard system; Bottom: Automatic System-Pontiac shown, others similar
Oct 11, 2011 | 2004 Pontiac Grand Prix
Can you replace the lights behind the instrument panel? the entire right side of my dash is no longer lit up
Sure Can
Buy bulb number 161
Instrument Cluster Finish Panel
Removal and Installation
1. Remove three screws along the bottom of instrument panel steering column cover (04459). Pull on instrument panel steering column cover to unsnap the three clips across the top of the instrument panel steering column cover. Remove the lower instrument panel steering column cover.
2. Remove four screws retaining the steering column shrouds (3530) together and remove the steering column shrouds.
3. Remove the three screws retaining the bottom of the cluster instrument panel finish panel (044D70).
4. Remove two screws retaining the cluster instrument panel finish panel above the instrument cluster face.
5. Pull cluster instrument panel finish panel to unsnap one retaining clip above the LH A/C register (19893).
6. Pull cluster instrument panel finish panel to unsnap three retaining clips on the RH side vertical edge.
7. Pull cluster instrument panel finish panel away from instrument panel (04320) far enough to disconnect the wiring connector(s).
8. To install, reverse Removal procedure.
I've never done #2, and #1 refers to the panel below the steering column. To remove it completely, pull it towards the driver's seat. There may be retaining clasps on it also.
May 25, 2011 | 1996 Ford Thunderbird LX
How to chnge dash board light
If it's in the cluster, see procedure below for removing cluster. If this isn't what you needed, please get back to me.
1997-00 Buick
CAUTION All models covered by this guide are be equipped with a Supplemental Inflatable Restraint (SIR) system, which uses an air bag. Whenever working near any of the SIR components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SIR, as described in this section.
  1. Disconnect the negative battery cable. Disarm the SIR system, as outlined in this section.
  2. Remove the instrument panel cluster trim plate using the following procedure:
    2. Remove the screws from each end of the instrument panel cluster trim plate.
    3. Remove the screw(s) from the lower edge of the right side of the trim plate.
    4. Open the instrument panel compartment (glove box) door.
    5. Pull the right lower trim panel plate from the instrument panel.
    6. Pull the steering column tilt lever and tilt the steering column to its lowest position.
    7. Grasp the instrument panel cluster trim plate at the right edge and slowly pull, working to the left to release the retainer clips. Remove the instrument panel cluster trim plate from the vehicle.
Fig. Instrument panel cluster trim plate and related components-1997-00 Buick models
      Fig. Front view of instrument cluster removal and rear view of the wiring harness connectors-1997-00 Buick models
      1. Remove the push-pin retainers from the top of the cluster.
      2. Rotate the instrument cluster rearward and disengage the locating pins on the bottom of the cluster from the instrument panel. Detach the electrical connectors and remove the instrument cluster from the vehicle.
      3. Installation is the reverse of the removal process. Use care to make sure all installation clips are properly located. Do not over-tighten any screws or they could force their way through their holes and the panel will not be held properly. Squeaks and rattles may develop later.
      Oct 18, 2010 | 2000 Buick Century
      Instrument cluster keeps going off and on. i have
      Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Silverado instrument cluster repair
      Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Yukon instrument cluster repair
      Jul 25, 2010 | 2002 GMC Yukon XL
      Iv lost my activation code and had to reinstall traktor 3 but have no activation code. what will i do?
      http://www.monova.org/details/2148225/NATIVE.INSTRUMENTS.TRAKTOR.DJ.STUDIO.3.CRACKED-DJNILO%09.html here is the link buddy 4 full version of this software enjoy..........
      Nov 09, 2009 | Native Instruments TRAKTOR 3 Full Version...
      1995 Cougar Odometer/trip-meter inop
      Section 13-01: Instrument Cluster—Conventional 1995 Thunderbird, Cougar Workshop Manual REMOVAL AND INSTALLATION Instrument Cluster Removal and Installation
      1. Disconnect battery ground cable (14301) .
      1. Remove screws holding instrument panel reinforcement (017A28) .
      1. Remove screws holding instrument panel lower shield (045G02) .
      1. Remove fasteners holding steering wheel column as outlined in Section 11-04 . Gently lower steering column.
      1. Remove fasteners holding the instrument panel finish panel (044D70) and gently pry off.
      1. Remove four instrument cluster retaining screws. (Do not remove screws from the instrument cluster main lens (10887) and instrument cluster mask (10890) ).
      1. Slide the instrument cluster (10849) to the right of the instrument panel opening and unhook the instrument panel harness from the back of the instrument cluster .
      1. Remove the instrument cluster from the instrument panel (04320) .
      Speedometer/Odometer Federal law requires that the odometer in any replacement speedometer (17255) must register the same mileage as that registered in the removed speedometer . Since the speedometer mileage cannot be reset on this unit, affix odometer sticker to driver's door pillar and record original vehicle mileage. Removal
      1. Remove the instrument cluster (10849) as outlined.
      1. Remove seven screws retaining the instrument cluster mask (10890) and instrument cluster main lens (10887) .
      1. Remove speedometer assembly.
      Installation
      1. Position the speedometer assembly to the instrument cluster back plate (10848) and install.
      1. Position the instrument cluster mask and instrument cluster main lens to the instrument cluster back plate and install the seven retaining screws.
      1. Install the instrument cluster as outlined.
      1. Connect battery ground cable and check the operation of the speedometer .
      please rate if this helps
      Mar 24, 2009 | 1994 Mercury Cougar
      Intel Motherboard Logo
      48 people viewed this question
      Top Intel Computers & Internet Experts
      Tony
      Alun Cox
      David
      David
      Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
