Question about Mitsubishi WD-62526 Projection TV
Red light for bulb indicator stays on.
Bulb has been replaced, light is still on. code 34. I have read similar concerns in previous posts, but did not notice any definate repairs. Is it the caps on the circuit board? If so, any tips on testing and replacing?
  • 1 more comment
  • tim6002 Jan 15, 2009
    Thank you for the response. My model (wd-62526) is the LCD projection model (not DLP) will this kit still work?
  • tim6002 Jan 21, 2009
    Recieved repair kit from service manuals website. Only 2 of the 8 capacitor location numbers exist on my power board. Any idea which other capacitors need to be replaced on the wd-62526 model?
  • tim6002 Feb 09, 2009
    Ok. I replaced the caps. Still same concern. I checked for voltage to lamp ballast, 330v present. What should i look for on the smaller wires? Is there a way to test the ballast?
  • Mitsubishi Master
  • 8,617 Answers
You need the V26 DLP power PWB repair kit. You can get it at the following link under the repair kit category and it has complete instructions with the replacement capacitors.
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2009
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jan 15, 2009
    yes, they are basically the same components, just let them know your model is the WD62526 and they will send the correct capacitors and the correct instalation info
  • Sonny Berry
    Sonny Berry Jan 21, 2009
    Did you mention that your model was the WD62526? Cause they are good about sending the right capacitors. I checked with my contact over there and they mentined that they hadnt had any orders for the WD62526. for at least two months but they said the WD62526 didnt use the two 3300uf caps they use (6) 1000uf 25v for C9A29, C9A32, C9A33, C9A36, C9A37 and C9A38
    (2) 2200uf 35V for C9A39 and C9A40
  • Sonny Berry
    Sonny Berry Feb 09, 2009
    the pl connector on the power pwb should have 340Vdc if thats present suspect the ballast
My hp w1907 monitor wont stay on
The issue if your light bulb behind the LCD matrix is burnt out you need to replace them. This is common for these monitors. The bulbs simply snap off an on by a connector to the high voltage power supply. When you open the monitor up, you will see he board with HV supply on it Trace the two (red an white) wires to the backlight (bulbs) and verify by looking at their ends looking for black discolor at he ends of the bulb (This means the interior of the bulb is carbonizing = shorting out). Most times the monitor will shut down into orange light, but sometimes it will not ignite the fluorescent bulb)(s).
Apr 23, 2014 | HP w1907 LCD Monitor
Replced bulb starts to power then fail red light blinks thre times
You might need a new housing! Sometimes, the housing can be damaged with a new bulb and it can caused the TV to want to shut off.
Mar 15, 2013 | Sony KDF-E60A20 60 in. LCD HDTV
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
Static
where do you live? are you in maryland?
Nov 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd 57731
Thats a lamp abnormality, sound like the two 3300uf caps on the PWB PCB need replacing
Jun 29, 2008 | Mitsubishi WD-52631 52" Projection HDTV
ERROR CODE 34 on Mitsubishi TV
I just had the same issue with my TV (dont know code), but the issue was with the power supply.
Feb 16, 2008 | Televison & Video
Red blinking light
REPLACE THE BULB ITS ON ITS WAY OUT COST ABOUT 200.00 AUS THERVE COME DOWN A FARE BIT NOW
Jan 04, 2008 | LG RU-60SZ30 60" Rear Projection...
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
Mitsubishi WD-62526 Projection TV Logo
142 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
