Question about LG Vu CU920 Cellular Phone
Can't set up blue tooth
I was able to pair the device properly. However I could never get the blue tooth function to work. So I deleted it to start all over. Now my phone can't even find the device to set it up again.
Strangely enough I went to the website where I purchased the blue tooth. It recommended holding down the button for 8 seconds as opposed to the 3 or 4 listed in the manufacturer's instructions. When I did this it found my phone. The pairing worked fine and now so does the blue tooth.
Posted on Jan 17, 2009
How do I get the blue tooth to cancel the "in use" signal"?" The phone or car functions do not respond to any prompts.
Maybe i don't get it, but you can simply turn off bluetooth on your iphone to cancel all bluetooth connections immediately. Re-Enable bluetooth to re-engage your connections.
If you wan't your iPhone to "forget" a paired bluetooth device just go into the bluetooth settings and tap on the little info badge for the device you want to remove. From there you can delete this pairing.
Apr 24, 2014 | Apple iPhone4 4G iPhone 4
I need to pair my bt2050 up to a new phone,it was originally paired wit another phone that i do not use anymore,im using a nokia x3 now and when im trying to find and pair up it says there is no device...
Hi Barbara,
Please follow the below steps, i hope your problem is resolved :-
  1. Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
  2. Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
  3. Switch off the bluetooth and restart it , so that it's ready to accept new connections.
  4. Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
  5. If the above method does not work , sadly your phone does not support the Jabra blue tooth.
  6. You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hope this helps.
May 11, 2011 | Jabra BT2050 Bluetooth Headset
How to you set it up with your phone
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
Feb 21, 2011 | Plantronics Explorer 230 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
My samsung bluetooth won't work with my tmobile mytouch slide
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 20, 2010 | Cell Phones
I WOULD LIKE TO SET UP A BLUE TOOTH CONNECTION
Take care.
Aug 20, 2010 | LG Shine CU720 Cellular Phone
Bluetooyh not working
the blue tooth has a solution.
It is in two ways.
Either the the blue tooth is not pairing well with other devices,
or
The blue tooth is corrupted.
When pairing phones together, make sure you pair the phone properly before you can use the blue tooth with other phones, because if you don't pair properly with another device, you will not be able to send or receive any data.
If the blue tooth is corrupted all you need to do is to flash the phone, that is the only way to restore the blue tooth back to be working.
Have a nice day.
Mar 15, 2010 | Nokia N70 Cellular Phone
Cannot pair my LG Shine with Jawbone 2. The usual code of 0000 does not work.
Hey welcome to fixya. i hope you 'll be fine.
The query you posted is not a big problem, because of some reasons this 'll usually happen.
  • First of all u have to check your blue tooth settings. You 'll go in the settings of Blue tooth. Check it out there that your phone's visibility should be " Shown to all" if it is not then open it and set that phone's visibility " Shown to all".
  • Second thing is it can be occur when the no of paired devices is extent to its limit so delete one or two paired devices if there is any, by going in paired devices which is also in blue tooth settings. and then make a paired device from whom u want to connect.
i hope these solution 'll solve your problem.
Hope for the best always
IF u like the solution,Kindly do rate me
keep using fixya
Feb 09, 2010 | LG Shine CU720 Cellular Phone
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
LG Vu CU920 Cellular Phone Logo
100 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
