Question about Jabra BT350 Bluetooth Headset Headset
Jabra BT350 wont stay blue to pair with phone
  • Anonymous Jan 17, 2009
    I'm getting tired of trying these things. They synch up the first time, then can only be used about 10% of the time, it just doesn't see it to pair or work at all. What a waste of money, this is my second one, same problem...
  • magicmagna May 11, 2010
    hold your call button down till it goes solid. than its in discover mode. make sure the tooth is fully charged. good luck.
5 Suggested Answers
SOURCE: Jabra BT350 stopped connecting
BR, I had the same problem with my BT350 and my Razr V3c. I was finally able to resolve the problem by doing the following:
- delete BT350 from device list on Razr
- start Razr looking for device
- put BT350 in pairing mode while phone searching (hold answer button till solid blue light)
- phone will detect BT350 and retrieve name
- select Jabra BT350
- say 'yes' to bond with Jabra BT350
- enter passkey - 0000
- phone will connect with Jabra BT350
Posted on Jun 01, 2008
Kidyubyub
  • 143 Answers
SOURCE: How to hook up a Jabra BT350 bluetooth
Make sure your cell phone's bluetooth is activated. Once you do that, you should be able to hold down the main button on the Jabra and once it turns on, it will connect with your phone.
Also, go to this site for Jabra. It links directly to the manual.
Posted on Jun 22, 2008
SOURCE: BT350
try turning bluetooth off . first erase bluetooth connections on phone. turn off phone and take out phone's battery for ten seconds. put battery back in and turn on phone. plug bluetooth into charger for ten seconds and unplug it. try re-pairing bluetooth with phone. This worked for me!
Posted on Oct 04, 2008
  • 13 Answers
SOURCE: jabra BT350 bluetooth
While the headsetis off, press and hold the power button for 6 seconds. It will first blick the light in several patterns, all in blue. Finally, it will come on solid blue, no blinking. It is now ready to be paired. Once your phone/PDA has detected it, the passkey /should/ be 0000, as in zero zero zero zero. That should do it. Best of luck! :-D
Posted on Jul 15, 2009
SOURCE: Can you pair the Jabra BT350 with an iPod Touch
how can i connect jabra bt350 to my ipod touch 2g 3.1.3
Posted on Jul 19, 2010
Im trying to connect my Jabra BT350 to my blackberry 8520 but my blackberry bluetooth wont even find the device even the Jabra headset is turned on.....i also lost my Jabra BT350 user manual cd and i dont...
The headset has to be in learning mode first for any phone to find it, press and hold the power on button for 8 seconds until the power light comes on and stays on then search for it with your phone, pairing code can be 0000
Aug 29, 2010 | Jabra BT350 Bluetooth Headset Headset
I do not have my manual to sync my bt350 with my new phone how do I do this?
Before you use your Jabra BT350, you need to pair it with your mobile
phone.
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a
‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the
option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a
typical mobile phone in fig. 5)
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’
or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4
zeros).
or go here http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
hope this helps
Jan 30, 2010 | Jabra BT350 Bluetooth Headset Headset
My jabra BT350
trying to pair my jabra to my lg vx8350 phone
Oct 06, 2009 | Jabra BT350 Bluetooth Headset Headset
Need help syncing to a LG 3850
Make sure you have headset off. Then hold on button until light stays solid blue. This is pairing mode.. Have phone search for bluetooth device.. use pairing code 0000 (4 zeros)
Feb 21, 2009 | Jabra BT350 Bluetooth Headset Headset
Jun 22, 2008 | Jabra BT350 Bluetooth Headset Headset
May 14, 2008 | Jabra BT350 Bluetooth Headset Headset
Mar 10, 2008 | Jabra BT350 Bluetooth Headset Headset
Connection prob
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at jjkernaud@hotmail.com
thank you all.
Nov 08, 2007 | Jabra BT350 Bluetooth Headset Headset
I couldn't get it to pair this morning
From the manual )link below),,,, 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press and hold the answer/end button until a solid blue light comes on. 2. Set your Bluetooth phone to ?discover? the Jabra BT350 Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* (See example from a typical mobile phone in fig. 5) 3. Your phone will find the Jabra BT350 Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Jul 28, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 Bluetooth Headset Headset Logo
210 people viewed this question
Top Jabra Radio Communications Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
vimal
vimal
Ed Nelson
Ed Nelson
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
