Question about Creative Labs MegaWorks THX 650 Computer Speakers
THX 650s not working after power outage
I had a power outage in the middle of the night as clocks were all off by a couple of hours. May have been a lightening strike as weather was bad. Next day the THX would not switch on. The fuse appears to be good. I read where others have found a little yellow capacitor sitting over the power leads to be the culprit. Does anyone have any other suggestions?
  • gsuburban Feb 24, 2009
    Same issue here...blinking led green light on the sub yet no power up with the control pod
Reset after power outage
Assuming this is a 220 volt dryer, are both sides of the breaker on? It should not blow only one side of the 220, but worth checking.
Jan 26, 2014 | Kenmore Dryers
In the middle of the night I heard a beeping, when I went to the kitchen to check it was my oven. The clock/timer was at 00:00, it wouldn't stop, clear or anything else, as it should. I could get it...
we , the experts , are all volunteer answerer's mostly with come back ground in either professional fixing or many DIYers.sounds like you had a power outage while you slept and needed to reset your clock only at the time . telling us about sears customer service is no great surprise ,
Feb 05, 2018 | Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
After a brief power outage, our Wii will not turn on.
It probly short circuted or somthing..Unplug it w8 a couple hours then plug it back in and try again..it might not work ever again if it was turned on durring the power outage
Nov 07, 2009 | Nintendo Wii Console
Alarm clock settings need changing, no instruction manual
In the top left corner there will be some bars showing that the hour anouncement is on. Simply press the minute button and these bars will go, leaving you in peace and quiet.
Oct 31, 2009 | Audio Players & Recorders
I have a cuisinart coffee maker. I can set the
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
Mar 21, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
There was a power outage in the middle of the night. My computer was turned on during the outage (Presario 2200). Now it will not turn on ; it is plugged in (was in a surge protecting power strip during...
Please try to remove the battery and than try to switch on the laptop directly from mains power and if it works than its your battery problem or if it still not starts than there is possibility of some components of your laptop may fired due power fluctuation. So go and contact service station.
Jan 08, 2009 | HP Compaq Presario 2200 Notebook
Projection display
I had the some problem a few days ago when we had a power outage during the night. Try unplugging it, leave it unplugged for about 10-20 seconds, and replug it back in. Reset your time on the clock and it should work then.
Nov 08, 2007 | Homedics Sound Spa Premier SS-5000 Clock...
Creative Labs MegaWorks THX 650 Computer Speakers Logo
71 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
