Question about Amana NAV5800A Top Load Washer
Washer vibrates vigously on high spin cycle.
I tried the uneven load correction with no results. I then did the self leveling method according to manual with no results and after putting my own level on machine and found if to be perfectly level With the washer empty I put the machine on the spin cycle and again it vibrated real bad and began to walk with the rear left leg moving to the left. Opened panel at the front bottom of washer in an attempt to look for oil, rust and any loose or broken springs. Everything looked normal. This machine was purchased in May 2005 and only used for six months of the year for two adults. Called repair man and he had no answer and only to tell me it might be the transmission. He left with my check for a forty dollar service charge. Help!!!
  • thomaslc23 Jan 16, 2009
    This is an Amana Washer 5800. It was suggested to raise the two front legs about the width of middle finger because manufacturer does not want washer flat on floor with front legs. Sooo I raised the front legs to the width of middle finger and then tilted mahine forward to adjust the self setting rear legs but they would not self adjust to level machine. Do you think the self adjusting legs may be defected? Help!!!
    Novelist:
    Champion:
  • 220 Answers
I don't know what kind of washer you have (make, front loader, top loader, etc) but it sounds like your basket is definately out of balance. I have replaced bearings on a front loader Frigidare, but I have heard of some of them having broken arms on the inner basket. Something like that would definately cause a condition like you describe. Bearings usually give plenty of warning due to noisy operation.
My washer has no "transmission" , just a motor and drive pulley and a belt.
What kind of washer is it? Also, I know you said the washer was level, but are all four feet solid on the ground? Sometimes a washer can be level, but still rock on its feet if one of the feet is short.
Posted on Jan 15, 2009
  • jetfixr Jan 16, 2009
    I probably should not comment because I am not familiar with the Amana washers, but If the washer is pretty new, it sounds like it is not level. Most feet are simply screw adjustable, but I would pull the machine away from the wall and get a good look at the mechanism to see how it adjusts. You may even go to an online appliance parts place and look it up and check out the illustrated parts catalog to get an idea how the feel work by seeing a breakdown of them.
    It may very well be that the mechanism on the rear feet is frozen and not working. Hope this helps some.
On the spin cycle my samsung front load washer wibbles and vibrates badly. I have replaced the shocks but that didn't work. What else could it be?
Check that it is level and that all the water is draining out when the wash cycle is complete. Check that the wash drum and all associated parts are correctly in place and are secure. Check the drum for excessive play, replace defective parts.
Also look for loose objects from clothing that may be jammed out of site but causing centrifugal throwout vibration.
Feb 17, 2015 | Samsung 3.7 cu. ft. High Efficiency Vrt...
Spin cycle massive vibration everytime. Size of load doesn't matter?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer in high spin cycle "walks" slightly away from the wall although when I put a level on it it appears to be level. The floor vibrates when it is in this high spin cycle. Feet are not raised very much...
make sure all the pegs are touching the ground. You may have the vibration dampner going out or the weight on the wheel is loose. You can find all that by unscrewing the back of the machine
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine is vibrating alot when in the spin cycle
Typically this is due to either having an VERY uneven (weight) load, (like having a blanket shift all to one side) or the washer needs to be levelled physically (like balancing a car tire.. high speeds tend to show imperfect weight distribution).
Feb 03, 2010 | Maytag Washing Machines
Front Load Frigidare washer bouncing on spin, very bad!!!
Hi, not sure if you have solve this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
Jun 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Hi, not sure if you have resolved this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Kennmore washer model #110.29842991
Try checking the drum bearings and shocks.They might have been damaged during the previous heavy vibrations. This is certainly not a problem with the motor. Will try getting some internal diagrams to disassemble in case you are handy and need them.Else call a local technician and get them changed for good.Good luck with the machine.Please do post comments and results.
Apr 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Whirlpool washing machine
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
installed, and the nuts should be tightened against the
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Amana NAV5800A Top Load Washer Logo
931 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
