Question about Canon PowerShot S2 IS Digital Camera
Blackness on camera screen
I have posted a problem before regarding my Canon powershot s21s camera. It has the screen blackness that so many cameras are having. I can't get any sense our of canon in Queensland Australia and one said it would cost $350 to fix it. Wanting to see if anyone else has this problem fixed for free and if anyone has anymore advice for me. Thanks
  • 2,985 Answers
Re: blackness on camera screen
If it is a recent purchase go back to the retailer. Try the Canon Web site Technical Support team once more, a low cost replacement may be ontainable Broadly speaking digital camera are not repairable The economics don't stack up and there is usually no new spares supply although a repairer may have accumulated stock of bits'n'pieces'n'pieces thatt may suit from other dud camera's and his charges will be high as mentiond
Posted on Jun 16, 2007
0 characters
3 Points
Our canon powershot s21s appears to be working except the screen and the veiwfinder are black. What does this mean?
A stuck shutter is another common failure mode for digital cameras, and especially so for the Canon S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Mar 22, 2011 | Canon PowerShot S2 IS Digital Camera
Unable to take pictures
Your camera will need a lens. Contact Canon regarding repairs (it may be covered due to a CCD Imager fault)
Apr 02, 2010 | Canon PowerShot S2 IS Digital Camera
Canon powershot s2 1s digital camera blurry pics
The lens assembly needs a repair service.
Either it as internal damaged parts, or a moving part got stuck.
This mean a professional repair service for it.
The cost of it may be $120.00 or more in most camera repair centers.
Best regards,
Jul 19, 2008 | Canon PowerShot S2 IS Digital Camera
Canon powershot s21s problem
The symptoms are indicative of a CCD imager failure. But you can sometimes jog it back by trying the following:
If the above works, recommend taking a photo at least once a week in a well-lit area to keep it running.
Jun 27, 2008 | Canon PowerShot S2 IS Digital Camera
Canon Power Shot S21s screen is black
Hey birdstrike,
According to the manufacturer there are two options. You can try pressing the display (DISP.) button, and if that doesn't work you are probably going to have to get it serviced by an authorized service center. There is a know problem with the CCD sensor on this camera and other model cameras that causes a malfunction when the camera is exposed to heat or humidity. Canon is covering this repair, and I have included a link below to the instructions on what to do.
Go Ahead. Use Us.
May 09, 2008 | Canon PowerShot A75 Digital Camera
Black screen
Sounds like you have a bad CCD. You can try contacting Canon to check out your options on how to get this repaired. Unfortunately the S2IS is not on their CCD recall list of cameras.
Mar 06, 2008 | Canon PowerShot S2 IS Digital Camera
PS s21s adapter for TC-DC58B
Yes you need to order the lens adapter/Hood set, available from the the Canon e-Store for $30.
Hope this helps.
Feb 27, 2008 | Canon PowerShot S2 IS Digital Camera
I have the same problem with my S21S. A long time ago, I tried to find-out what size SD cards would work on this camera. Since there was NOTHING listed in the specifications, I tried a 4GB card. The camera simply would not recognise it, but worked fine when I returned the 1GB card to it. A few days ago, I popped-in a 2GB card to see if that would work. The camera seemed to accept it, and created a directory on it, but this is when my screen went blank. the only thing that is constantly present is a small hand symbol. The stored images can be displayed, and the menus work... I think its locked-up. Is there an "all reset" button, or sequence somewhere? TIA!
Nov 14, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
65 people viewed this question
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
