Question about Creative Labs Zen Neeon MP3 Player
Player can't charge
Plugged neeon into usb usual stuff appears on neeon screen BUT charging icon (the top right one) is static and is not blinking - the icon is supposed to alternate with some battery bar icons what's wrong?
This has happened to me before,you might want to try using a different usb cable.I did this and it worked fine since then.
Posted on Aug 01, 2007
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
How do I operate my Philips go-gear 8GB mp4 player. Serial # RK1H1051038306, model # 06095819004. I can't make out the users manual. What I am tying to do is, transfer my class lectures, recorded in mp3...
I have a Philips go-gear 4GB player. There is no charger included. To charge the player, use any firewire/USB cable and connect the device to a PC or laptop. While the device is charging, the battery icon is blinking. When it is fully charged, the battery icon will stay static.
To copy to the device, open Windows explorer. Look for the Philips Go-gear folder icon. Open the Philips folder and Copy you music files inside the device's my music folder. If the file is video, copy the file in the my video folder.
Once the device is fully charged, disconnect the device by right-clicking on the Safely Remove Hardware icon on lower right portion of your PC screen. Select Safely remove hardware then Choose the philips go-gear device to eject.
Power on the device then use the navigation keys to select the files you like to play. Click ok or the play button.
Jan 21, 2011 | Computers & Internet
Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Apr 07, 2010 | Coby MP-610 MP3 Player
Got the Ipodtouch today and cannot find instructions on what to do. Do I charge it? How? How do I get all the stuff on the screen so that I can start to have fun with it. It is just black. Thanks much....
You should be able to turn it on right away by holding the button on the top of the device until the apple symbol appears on the screen. Then, you'll want to be sure to keep it charged by plugging it into your computer. Hope this gets you started. Have fun!
Aug 18, 2009 | HTC Touch Cellular Phone
How do i change the battery
  1. Remove the cap over the USB plug and insert the unit into the USB port of a desktop or laptop computer. The computer will recognize the Sansa Express as a new hard disk drive.
  2. Locate the battery icon on the upper right of the screen. The battery icon will fill in with color as the unit charges. When the icon is filled in, the charge is complete. The unit will fully charge in about 3 hours as long as the desktop computer or laptop is powered on.
  3. Plug the unit into the USB port of a car or AC adapter and then plug the adapter into an AC outlet or an auto cigarette lighter socket, as the case may be. The Sansa Express will charge in about 3 hours.
Jul 17, 2009 | SanDisk Sansa Clip MP3 Player
Is there any such thing as charging my mps nextar MA933a via the USB port? I just get sleepy z's on the display when I connect it to my computer.
Here is what I found:
Connected the player to the PC with and without prior power on successfully
OSD first displays message “Starting…” then:
Icon appears on screen with a picture of a computer monitor to right and mp3 player icon to left
When mp3 player is communicating with computer or sending information, an appropriate directional arrow appears between the two icons; when transferring files using Windows Explorer, the arrow reverses direction appropriately; when there is no activity either way, a series of “Z z z” ‘s appear on screen
Battery indicator icon also appears to right – new AAA battery resulted in a fully charged icon upon startup; no battery whatsoever resulted also in a fully charged battery icon appearing
-Tha Mp3 Doctor
Feb 02, 2009 | Nextar MA933A MP3 Player
ZVM won't charge
Usually this problem is due to the firmware. If you upgrade the firmware to version 1.62.02, this problem usually will disappear. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
Here is what you'll need to do to save your Zen: you will need a charger for the operation. I recommend buying a brand new charger from the Creative Labs website or a used one here, instead of getting an aftermarket one off Ebay. Aftermarket ones tend to cause problems or fail to work altogether.
Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected the charger. Once it is powered on, connect the USB cable to your computer.
If your Zen does not power on when connected to the charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
Download the firmware to your PC, then reboot your PC and connect the Zen via USB cable. Open the firmware icon to begin the download.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Oct 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen Neeon Frozen - USB Display
we have the same problem
but there is 1 way to solve it
wait for the battery to drain and charge it
hope it helps you : )
Jun 01, 2008 | Creative Labs Zen Neeon MP3 Player
Recharging?
This product uses a built-in rechargeable Li-ion battery which is charged by usb power. So when you plug it into your Computer or Laptop it recharges with the power it get through the usb port. You can also buy a USB AC Charger for MP3 Players it plugs into your wall outlet and has two usb ports on the bottom to plug into. You can get on at Walmart for about $15.00 called MusicPower
Duet:
http://www.walmart.com/catalog/product.do?product_id=5750794
There are even USB Charger for you Car as well.
Charging Section of the User Manual
This icon will be displayed at the upper left corner of the screen. The following pictures indicate the
charging status of the battery:
(1) When the battery is charging, the battery icon will be changing from an empty battery to a full battery icon to indicate the process.
(2) The following icon will replace the charging one when it is full but the power supply is not being cut off. Which is a Battery Icon with a Lighting Bolt in the center of the icon.
(3) The player will automatically shut off when the power is used up. In this case, all setting will be
saved.
You can get this information on the Nextar website below and the right hand side there section call Downloads click on the MA715.pdf.
http://www.nextar.com/frontend/proddetail.asp?pn=MA715&co=10000309
Later
Nov 16, 2007 | Nextar MA7151B MP3 Player
My Computer Won't Read It!!!
These symptoms points to a bad hardrive. Replace the hardisk and reload the latest firmware.
If your out of warranty with your Neeon, open it up. Loosen the 2 screws at the bottom of the player and remove it. Then carefully pry open the back plate using a small flat screw driver and remove the battery (it has a mini connecter on the top left, inline with the USB connector).
Remove the front cover. You'll find the hardisk on top of the board below the LCD. Remove it carefully from the connector. on its right side.
If you got a new HD, replace the old one and reassemble your Neeon.
Next download the latest Neeon Firmware Upgrade here:
http://sg.creative.com/support/downloads/download2.asp?MainCategory=213&Product=12214&dlcentric=9534&Product_Name=ZEN+Neeon+5GB%2F+6GB&OSName=Windows+XP
Firmware above is for Windows XP. You can download a version of the Firmware at Creative site in your region for your specific OS requirement...
Before
To install this firmware upgrade:
1. Press and hold the Play button while connecting your player to your computer's USB port.
2. Continue to hold the Play button for 10 seconds after connecting your player to your computer.
3. Release the Play button when the Find New Hardware dialog box appears on the screen.
4. Follow the instructions on the screen to install recovery drivers for your player.
5. Download the ZenNeeon_PCFW_LF_1_011_FM.exe file into your local hard disk.
6. Double-click the firmware upgrade file and follow the instructions on the screen.
I found the above instructions with other Neeon's forum here:
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=176728
You'll have the option to format and reload firmware. Choose that option. Wait for the upgrade progress to finish.
When it's done, your player will connect and recognized by your computer. If it shows in MY COMPUTER as removable drive, then your in luck!
Proceed by drag and drop method of transfering your music files or using the CREATIVE MEDIA SOURCE ORGANIZER.
I'm currently looking for a way to hack the Neeons Hard Drive and replace it with a CF card just like what I did with my Zen Micro. Unfortunately the first CF card I bought (1 Gbyte) did not work on the Neeon, the XP wont recognize the player.
But I'm not giving up, I had to find a better replacement that match the compatibility requirements of the Neeon. I'll try different brands and speed. The CF card is much more robust and shock free. It reads faster with no hang-ups.
I'll post my results in the future if I succeed.
Sep 26, 2007 | Creative Labs Zen Neeon MP3 Player
Creative Labs Zen Neeon MP3 Player Logo
51 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
