I have a Sony vaio PCG-K45...and my CDWR/DVD drivers doesent work at all , and doesnt even appear on the hard disk drives ..i think i might need to install it , do you know where can i install them.. my driver is: QSI CDWR/DVD SBW242C - O
  • 8 more comments
  • gianb Jan 15, 2009
    ok....
    when i go to MY COMPUTER icon ,on HARD DISK i dont see (DISK :E ) which i guess is the one to play CD's.....my main problem is that i cannot play CD's.
    how do i check my BIOS SETTING ?
    ok...
    when im in the
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}.
    i see 3 boxes below
    0000
    digital audio
    Properties
    where do i press ? ... do i have to delete something there ? or update soemthing ?
    ok....
    when i highlight on the left
    i do see lowerfilters , but i dont see upperfilters on the list......do i still have to delete lowerfilters ?
  • Anonymous Jan 16, 2009
    thanks,
    i just did that , i contact sony , they told the same thing ....but the cd/dvd ddriver still missing on the my computer icon ....i dont where to go , i have tried everything .. any other ideas ?
    thanks
  • gianb Jan 20, 2009
    i have winows Xp home edition ..not windos vista ....
    but anyways , i would like to thank all you for your help..im still struggling to fix this problem, i will see if find another solution,
    thanks
  • machadojr_fe May 11, 2010
    what jennifer said is correct you only have to delete the one you can see
  • Jennifer_H May 11, 2010
    if you only see one only delete that one you will not have to delete the other once you have reboot the computer
    open the Windows Registry by clicking start and then run and typing in regedit and pressing enter and then navigate to
    Delete the keys named UpperFilters and LowerFilters and reboot the machine.
    do you need help getting the computer to see the hard drive or the dvd drive?
  • 916 Answers
Try finding your driver here
http://esupport.sony.com/US/perl/support-info.pl?info_id=141&mdl=PCGK45
I'm not sure which version of Vista you are using but there are updated drivers that you can find there by clicking on your version of vista.
Posted on Jan 17, 2009
  • machadojr_fe Jan 20, 2009
    Oh I'm sorry usually that error occurs most often with vista I should have asked you before what OS you were running right click my computer click properties and then go to the device manager and uninstall the cd-rom or dvd drive you see listed there and then restart windows,
    this should auto-detect the drive and reinstall the cd-rom drivers.
    Problem Solver:
  • 18 Answers
Check your bios setting if your optical drive
is enable.
Posted on Jan 15, 2009
Hi i have a sony vaio pcg-505gx laptop and once i turn it on it ak me to press f1 to continue and then it takes me to ascreen that sayd invalid system disk replace the disk, and then press any key what...
windows cant find the operating system to boot from check that there are disks in usb cd/dvd or floppy if there is an external floppy drive if there is nothing in these drives
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery and computer ram make sure they are securely seated
hope this helps
Jun 16, 2011 | Sony VAIO PCG-505 PCG-671L PCG-700...
I have windows XP on My Sony Vaio PCG K45, but when i switch on my laptop it get boot upto the blue screen with windows XP logo and then it get stuck. I request you to help me to sort out my...
It is problem with the boot sector. There is a bad sector in the MBR. Whatever you do will not be a solution to remedy this problem. First of all you need to take a test of the primary hard drive. If it passes the test, backup all your data using a linux LIVE CD and then format the whole drive (all partitions) to ntfs using a Vista installer dvd. Re-install XP into the first partition of the drive. This will fix the problem parmanently.
Feel free to contact for any questions further. I am following up.
Have a nice day,
Regards.
Dec 13, 2010 | Sony VAIO K45 Notebook
Sony Vaio PCG-K45. My speakers are not working
May be yor codec (decoding system) is missed. Try different player, also if using Klitecodecks reset settings. Find sound program and turn off 5.1 or 7.1 sound and choose 2 speakers.
Jul 30, 2009 | Computers & Internet
I cannot set up wireless connection to my printer.
Check your drivers. Or go to the Canon site and download the latest ones.
Jul 07, 2009 | Sony VAIO K45 Notebook
Hard drive compaibility
It should wark just fine
Feb 11, 2009 | Sony VAIO Notebook
Sony pcg k45
Put the cd in and restart. If it doesn't give you a message to press "x" to boot from cd, then you need to chage the boot order in the BIOS.
To get into the BIOS, restart and press del or F2 (it might say something on the screen like press del to enter setup) that is the BIOS.
Change the boot order to CD first.
Dec 18, 2008 | Sony VAIO K45 Notebook
Computers & Internet Logo
83 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
