Question about Epson Stylus Photo R2400 InkJet Printer
Epson r 2400 top trashcan light and ink light flashing
Printer totally locked up and not even connected to computer - have unplug printer from power with out any results.
  • jane106 Jan 16, 2009
    My Epson R2400 was just refurbished by Epson in July 2008. Today I turned it on, the green light flashed briefly, the print heat twitched and made just one noise, and then the red ink out and paper out lights started flashing alternately. The print head never unlocked and cannot be moved. I unplugged the cable to the printer, I turned it on holding all 3 other buttons, I unplugged the power as I turned it on -- none of these have helped. The last time I used the printer I deleted a job while it was printing because the magenta was not printing well. I pulled out the half-printed page and then shut down because I had to go somewhere.
  • ant-ney Jan 18, 2009
    My Epson R2400 makes lots of noise...as if it wants to print..but nothing happens. I get the message that media is improperly looaded.
  • Epson Master
  • 419 Answers
For Jane106:
The ink-out and paper lights flashing alternately indicates the "service required" or basically ... "change my ruddy diaper, it's full of ink".
This is not as bad as it sounds and you have a few options:
1. Take it to a service center and have it serviced (ie: have the waste pads replaced)... It's expensive though so be warned.
2. Download the SSC utility (Google: SSC epson reset) and use this to reset the protection counter in the printer memory.
Note: READ the manual, it's not overly intuitive.
If you've gone with 2. you'll still need to do something about your waste ink and the simplest is really to modify your printer to redirect waste ink from the cleaning pump to an external tank.
Again Google is your friend so keywords like "Epson waste ink R2400" will find what you need. Some kits are better than others but then I'm biased :)
Hope that helps.
Posted on Feb 15, 2009
Lockup
You need to do some cleaning on this printer, because that causes it not to work , you can take the parts off from the printer and use alcohol to clean the dirty parts of the printer..
Hope that helps.............
Sep 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson 2400 problem
Maybe your epson printer has reach the printing warranty.. try to reset your printer by using SSC epson printer resetter.. ^^ cheer..
Mar 13, 2009 | Epson Stylus Photo R2400 InkJet Printer
Epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
Mar 07, 2009 | Epson Stylus Photo R2400 InkJet Printer
Red & Green Lights keep flashing on Epson Stylus Photo1280
I had the same problem. You need to reset the waste ink counter:
1. Turn printer off, unplug power cord. Disconnect computor interface cable (back of the printer).
2. After one minute, reattach power cord, but not the computor interface cable.
3 Hold down the LOAD/EJECT and CLEANING buttons simultaneously (cleaning button has ink drop on it) .
4 Turn printer on. Release all buttons as soon as the paper out light flashes.
5 Quickly press the cleaning button, and hold for 10 sec while paper out light flashes.
6 Release the button and the printer will initialize.
7. Once the initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on and try to print your document.
This process worked for me. Good luck!
Feb 01, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Red light on printer blinks continuously
http://inkjetprinterhelp.us/epsonSSC.html
photo r220
this site will reset your protection counter on the overflow ink well for excess ink during head cleaning.
its called the ssc service ultility.
it really works, i reset mine on 6-18-2008.
main website
http://inkjetprinterhelp.us/epson.html
good luck!
Feb 27, 2008 | Epson Stylus Photo R220 InkJet Printer
2200 locked up
disconnect the printer from the computer - power off printer - check for obstructions / torn papers - power on
if paper light is still on/flashing and pressing it does not do anything - you got a hardware issue - call manufacturer for reccomendation
this might help also - http://www.epson.com/loyalty
Dec 23, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson stylus 880 printer
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Oct 08, 2007 | Epson Stylus 880 InkJet Color Printer
Epson Stylus Photo R2400 InkJet Printer Logo
1,802 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
