Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Starbucks barista SIN 006 wiring
Hello mirran,
I was reading some of your replys to others and one stood out for a problem I'm having. SIN 006 machine, and I purchased and installed a rebuild kit (seals, gaskets and other parts) prior to starting this operation The machine worked. After, the pump does not seem to come on when I open the steam valve. I have tried to find a wiring diagram to double check my connections but no luck. Is it possible you may have one? Please also respond to john2459@comcast.net as well
That's simple. No Power? It is the switch. I sent it out (Not far from me) and they replaced it. Cost me $35 inclusive. well worth it!
The other guy with no steam? He simply has to be patient. When first starting the machine that has been worked on, simply open the STEAM VALVE and let it rip until the water comes through, may take a few minutes but it will come through. I owned that model for 15 years and know all about them. Jean Claude, Ontario Canada
Posted on Jan 23, 2010
Hey, Ive got the same problem and can not find any help on coffee geek, any links?
Posted on Aug 24, 2009
Hi there,if you look on a site called Coffee Geek it has the wiring for your machine.
I have one of the sin 006 and there is no power at all,can you help please.
regards
Bob
Posted on Feb 01, 2009
Saeco interchangeable parts
look on the model plate and see who made it
n contact them on the net and see what is available.
May 15, 2015 | Saeco Coffee Makers & Espresso Machines
I have a Starbucks Barista Espresso Sin 006 that I got used from someone. They hadn't used in it awhile and didn't have the manual. I'm told that before using I should Prime it. The instructions says...
Hi
Since the machine hadn't been used in a while you might have a stuck check valve in the pump. You say it hums. Does it rattle or just hum? If it hums something is stuck in the lines that is keeping the pump from moving water. If it rattles and makes a lot of noise its the pump check valve or it could be a plugged flow meter/ intake line.
Jan 16, 2011 | Starbucks Saeco Italia Digital Barista...
Starbucks barista machine steam valve leaks.
Hi Sammy,
I think you have to replace the steam valve and the gasket in it.
Best regards
/Mirran
Nov 07, 2008 | Starbucks Saeco Italia Digital Barista...
That was not good you not fixed the machine:-(
/Mirran
Sep 10, 2008 | Starbucks Saeco Italia Digital Barista...
Broken door hinge
Where are you living?
Best regards
/Mirran
Sep 08, 2008 | Starbucks Saeco Italia Digital Barista...
My wife has a Barista SIN 006 (1995)
I will send you some documents, on the second page in the document you should check position 33, 34, 36 and 37 if 33 not work satisfactory then you not get any espresso.
Hope you get your machine to work again.
Have a nice day
/Mirran
Aug 30, 2008 | Coffee Makers & Espresso Machines
Saeco Italia Sup021 YR flashing red malfunction light
I found a link in the forum where there are some informations.
http://cerinicoffee.com/Saeco_technical_documents.asp
Hope this will help you.
/Mirran
Aug 22, 2008 | Starbucks Saeco Italia Digital Barista...
NEED INSTRUCTION MANUAL FOR STARBUCKS BARISTA TYPE SIN 006
Saeco made several models similar to the Barista type, but slightly different cosmetically. If you have the a Starbucks model, it is the same as the Rio Vapore. You can find an operating manual, along with parts and repair diagrams at partsguru.com. I'd download all of the manuals and diagrams in case you need them in the future. Here's the link (I have not had any dealings with partsguru.com personally).
http://www.partsguru.com/SaecoRioProfi.html
Aug 17, 2008 | Saeco RIO Vapore
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
1,381 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
