Mercedes commans sat nav version 4.1 for E220, is saying off road, and when at home is showing on map that I am somewhere in the National Park Peak District. I have been told to remove fuse for sat nav should be no 28 but in boot of car near sat nav cassette fuses in box only go upto 20. Am I looking in the right place?
These navigation disks are prone to contamination from dust particles over the years. If the disk is not damaged (scratched), you can try gently cleaning it to see if that works. You can also try a special lens cleaning disc to clear any dust from the reader.
However, if you have you followed all the owners manual instructions for removing it and it won't, you have a much more serious problem with the system. All I can suggest is a trip to a dealer to see if they can help.
check the sa/nav fuse in engine compartment. may be blown. or sat/nav dvd reader is in trunk of car on passenger side above wheel arch, unscrew holding screws , disconnect power cords at rear, & get unit checked. it may be finished. can repair or replace..both expensive.
Tony, check the door to the nav unit in the trunk, when the door is open there should be a small plactic point on the door that fitds into a tiny hole on the nav unit, if this plastic point on the door is missing thats the problem, I had it happen to me. ken. [email protected] let me know what you found out, thanks
Under the cd slot you will see a long thin rectangle that can be gently pryed out with a knife tip on the right side of the rectangle. under that cover there is a small button. push that and out comes the nav disc. Voila solved
same problem, disc is located under passenger seat, talked to honda canada , alpine and honda usa, they dont make a disc for 05, couldnt get nav in 05 cannadian pilots , they dont even make north america disc just stricly usa maps
