Door on w/mach will not open
The handle seems loose but will not open door... how can i get the door open to empty it??
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Remove door
I recommend calling either the manufacturer or the place you bought it from. Quite likely need a new door.
Jan 29, 2014 | Candy FP855 Electric Single Oven
2001 BMW X5 Unlocked driver door wont open from inside or outside
handles may be in good condition but the lever on the latch itself may have came loose. your mostlikley looking at dismantelling the apolsery with the door closed to rectify it.
Apr 21, 2013 | 2001 BMW X5 3.0i
2003 volvo xc90 t 6....drivers door will not open from inside, ok from outside. self locking ok open/shut. It has appearance of child lock active which for a drivers door doesn't exist i assume. the...
the inside door handle is probably broken. the cable may have popped out but usually its because the clips on the inside door handle break off. luckily you can just replace the handle and not have to get a whole new door panel
Jul 11, 2011 | 2004 Volvo XC90
Have a 1998 Jimmy, the driver door is stuck in the close position and can not close the door. The handle seems to be working properly; inside handle moves the cable that permits the door to close and...
with the door open see if latch is stuck in close position . If so hold handle open and pry with screwdriver to open latch ..If that works latch needs to be lubed for smooth operation
Feb 17, 2011 | 1998 GMC Jimmy
Door handle has come loose from inside . Can lock and unlock but not open door with outside handle
If you take the inner door panel off and have the window up, you should be able to access the area to tighten the handle down. If the handle assembly is still tight, but the handle its self seems to have no resistance, the plastic clip where the release rod attaches may have broken.
Oct 05, 2010 | 2009 Dodge Journey
I went to open the driver side door and the exterior portion of the handle came loose.. I worked it back in and it seems to work, I'm opening the passenger side door to get to the driver side inside handle...
the door handle is either broke or a part of it has slipped loose, either way, you'll have to remove the inner door panel to get to it, this is not difficult, a few screws and the panel is retained by push in type plugs that can be pryed loose. the entire door latch assy is held in by screws and is serviced by replacement, the difficulty come with very tight area to work in, and is irritating and time consuming, if you are not good with tools i'd suggest a good mechanic or body shop. always get a quote!!
Oct 26, 2009 | 2006 Buick Lucerne
Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Jul 07, 2009 | Indesit W 123 Front Load Washer
Trunk/hatch will not open. handle seems loose, no action. Wondering if something is broken. How would you repair it. Can't find any other way to open trunk. The glass window part opens.
2000 ford explorer back hatch handle loose door locked The linkage on the back hatch came unfastened and the handle was loose. Ford uses plastic fastener clips over perfectly good threads to hold this together. The outdoor plastic handle is only conected to the car with two aluminum ribets. One was already missing on mine. But if you just want to open the door, you can rip the handle off and pull it out. hopefully you won't crack the plastic. You can see the linkage screw hanging as you look up through the left hole. Grab it with a plyers and apply a steady force down. This will open the hatch. I just rigged up a different handle and put a nut on the treads to hold it together. This can all be done without tearing appart the interier and may only take 20 minutes. I used a rope and handle from the garage opener, a medium size washer and a nut. First make a small loop, with a small hole to slide over the linkage screw, then the washer, then the nut. Slide the other end of rope through the handle, move the handle very close to the vehicle and tie the not close. Trim the rope and wala ... the hatch works. Or you can pay $300.00+ to have it fixed with the clip.
Jun 30, 2009 | 2000 Ford Explorer
Kitchenaid dishwasher KUDR24SE...cannot open door
did anyone have a solution? i have the same problem.
May 16, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
