Question about Water Heaters
No water from hot water faucet
I have a Paloma tankless water heater PH-28RIFSN (Natural Gas) located in the basement. Today it is -31 degrees and when I turned on the hot water faucet, there was no water, not a trickle. The unit does not read any errors, all valves are open. There is good cold water pressure. All necessary pipes are insulated, the outside vent is clear and the gas intake valve has been increased in size to accommodate usage. We are on a well and am concerned that the pipes are freezing, therefore can this be a cause for no water from the hot water faucet. Would the water in the tank be from previous use or is it continuous flow from the well when the tap is turned on, therefore allowing only cold water use? I am in need of immediate help here, I do not need any burst pipes today! Thank you.
  • 1 more comment
  • 4th gen plbg May 11, 2010
    One other note. If you do not get any water out of that relief valve, then it could be that the vent for the heater froze the water in the heater. Is the heater located inside of the house?
    That heater will have a relief valve on it. Have you tried to to manually open it and see if it discharges water? If it does, you probably have a frozen water line. Im from ND and I understand -30+ below weather. One note on insulation. Always think of it as keeping the temp in, not keeping cold or warm weather temps out.
  • Anonymous Mar 12, 2014
    I don't know where the white pipe is supposed to go.. rusty water is dripping from it. We have to keep refilling water all the time.. I can't see a leak anywhere..We've used a lot of gas in just a few weeks, woke up today with an empty gas tank.. Any ideas to where the white pipe goes? And is the fact that we've been refilling water a lot the reason that we've used so much gas do you think? Would be grateful for a quick reply :)
    kind regards Jill
    Novelist:
  • 88 Answers
Thanks for your question, sounds to me like you have a frozen line, I used to live in Northern, MN on a well, and had alot of time un-thawing water lines, yes it is continuous flow, sorry for having to say this but you need to immediately start tracing your hot water lines and see if you have any leaks, bulges, or ice forming on the line, tap the line with a screwdriver to hear the difference in sound when you find the frozen section, here is the tricky part, if its (pecks line, plastic) then you need to call a plumber, if copper, you can use a torch to un thaw the line, but use extream caution when doing this as many people has accidentally started fires, my best advise is to call a plumber, hope that helped, please get back to us and let us know what you find, thanks again, mr.grzz
Posted on Jan 21, 2009
Thermostat is set @120 then drops to 65 and starts flashing. Water get cold. What is the reason . Thanks
Rheem Paloma tankless computer? No error code? One possible cause; Crossover caused by bad single handle faucet cartridge drawing cold water into line causing shut down of tankless burner?
Copy following links for resources:
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment as needed.
Gene
hh
Aug 19, 2013 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Code P1 appears in my Paloma gas water heater
Copy following link for troubleshoot resources Rheem/Paloma tankless:
http://waterheatertimer.org/images/Rheem-service-valves.jpg
Error P1 is not enough water flow.
Clean water filter located on cold water inlet at top of cold pipe when cold enters unit
Test single handle faucets for crossover
Check if faucet can fill 1 gallon can in 30 seconds.
Apr 15, 2013 | Water Heaters
What can cause Hot/Cold spikes on an RTG74-XN
Crossover, low hot water flow, low water pressure, sediment in water lines or heater, heat exchanger needs to be de-limed, water filter needs to be cleaned, water heater temperature set too high, incoming water temperature too high or too low depending on model, MUD or PUD districts with pressure spikes, dirty faucet aerators, loose wires, bad sensor, faulty PD-board, bad venting, dirty burner and combustion parts, etc.
Crossover
Clean water filter monthly, de-lime tankless yearly
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
No error code:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Overcoming fluctuating temperatures:
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
Resources:
Sep 20, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
What size venting do I need for the ptg-42-pvn?
3" category III stainless for special venting
Tanklessking shows Category III stainless steel vent kit for this model
3" vent
http://tanklessonline.com/rheem-water-heaters-RTG42.html
ptg-42-pvn has minimum 31,000BTU and max 118,000BTU
Max water temperature 120 degrees F
Spec sheet says: 3" special venting
http://www.palomatankless.com/products/42/specifications.html
Hart and cooley show special vent 3" stainless thru-the-wall vent
http://www.hartandcooley.com/specialgasvent/PDF/851515%20Tankless%20Water%20Heater%20Installation%20Vent%20Kits%20sell%20sheet%20-%20HC%20-%20low%20res.pdf
Hot water sources shows thru-wall or thru-roof
http://www.hotwatersource.com/RTG42PVN-Rheem-Indoor-Natural-Gas-Tankless-Water-Heater/RTG42PVN,default,pd.html
http://waterheatertimer.org/pdf/Tankless-roof-vent-installation.pdf
Aug 17, 2011 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Error 13 paloma tankless hot water system. no hot water
Before calling service technician, open following links for error codes, Rheem/Paloma chat and tech support, and possible manual:
http://www.fixya.com/support/t3444443-paloma_tank_less_water_heater_flashes
Error codes are considered start-point for troubleshooting.
Tankless manuals recommend yearly service including burner cleaning, gas pressure and plumbing check, de-liming etc to prevent problems and so technician is familiar with that specific unit.
Aug 05, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
My paloma tankless water heater shuts of but the display goes blank and does not show an error code.
check to make sure circuit breaker is big enough to handle your unit if not get correct size
Oct 07, 2009 | Rheem Paloma PH-28R IFSN / RTG-74PVN...
I get a P1 error code on my Paloma tankless water heater. It blinks between the P1 and the tempature setting
Water inlet temperature to the heater is the same as preset on the controller.
I had this happen to me becouse I have a solar tank with temp of
135 farenheit.
Once I bypassed the sollar tank..no problem
Sep 24, 2009 | Rheem EcoSense by 7.4 GPM Tankless Water...
Water Heaters Logo
437 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
