Question about Microwave Ovens
I just bought a Whirlpool Velos Microwave Convection over the range microwave. We are in the process of installing it; had to change the vent, electrical hookup, etc. My question is, as large as this thing is, and as heavy, will the cabinet be able to support it? I have plaster walls which will give it some more support, but I think it weighs like 240 lb. I would hate to put up a shelf, that would seem pretty dumb, but I am concerned.
  • Microwave Ovens Master
  • 9,098 Answers
The installation manual will specify the requirements.
If not, I would contact Whirlpool customer service.
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
Posted on Jan 18, 2009
I have to slam the door very hard for it to close correctly what would cause this problem?
Incorrectly adjusted door catch. They have movement on them to allow a tight seal due to the microwave capability.
I just found the specs and instructions on it.
Whirlpool Gold 2 0 cu ft Velos SpeedCook Oven
Mar 09, 2016 | Whirlpool Gold 2.0 cu. ft. Velos SpeedCook...
Whirlpool Velos GH7208XR Convection works fine but microwave says door open and will not work on microwave. could it be door latch but then why does convection work?
I'd check the primary and secondary door switches for proper operation. Could be a failed switch, or adjustment issue on the switch assembly or door latching mechanism.
You also might have a failed thermal protector on the magnetron.
Feb 16, 2016 | Whirlpool Microwave Ovens
Installing a microwave / convection oven above a stovetop
Needs to be properly vented to outside the house. Only install a microwave that's designed for over-stove use in this space.
Aug 25, 2014 | Microwave Ovens
My microwave vent cover is sticking (grease?) & I can't release it to clean. Anjy suggestions?
Magnetic vent cover also has one popular feature. It can be painted or applied wallpaper over it and can even be covered with carpet to blend with the room and remain unnoticeable.
Jan 14, 2013 | Whirlpool Gold 2.0 cu. ft. Velos SpeedCook...
I have a Whirlpool Velos Microwave/convection over the range microwave. It is 2.5 years old. Tonight, after putting the fan on the unit is now indicating an Error message "F2H1-Hood Keys Stuck- the...
Sounds like the pads that you push on the touch panel are stuck, will probably have to replace the whole touch panel. On units installed over the oven, they typically plug into an outlet in the cabinet above the microwave. if not, try flipping your circuit breakers until you find the one that shuts off the Microwave.
Aug 24, 2017 | Microwave Ovens
Velos Microwave turntable works, product heats but does not vent
can you give me more information what is it not doing
come back to me
Aug 18, 2009 | Whirlpool GH5176XPS Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Microwave Ovens Logo
135 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
