Question about Kenmore 22422 Top Load Washer
Washer wont spin
Washer does spin but not actually most the time clothes still have too much water left in them. this morning water was on the floor in front of washing machine. thank you very much for any help to repair thid. linda beck
  • Kenmore Master
  • 8,205 Answers
Put some draino crystals in the drain or some liquid plumber foaming pipe snake. I am thinking you have a slow drain. If that is ok then it has to be the pump. You might want to inspect the innards of the pump for strings and sand or other stuff. And give the coupling a look see. READ MORE CLICK HERE.
Posted on Jan 22, 2009
My washing machine keeps getting water in it after the cycle is over. This morning I came in and my empty washer was filled with water and had overflowed onto the floor. Help! There are also times when...
mine also remains wet and soggy, even after the spin cycle. However, I have not, as of yet, (and hopefully won't) begin having overflow problems.
Mine is jumping around the laundry room - as though in an unbalanced cycle. We discovered that one of the "feet" that the washer stands on needs to be adjusted, upward or down, so that the washer stands balanced and evenly. The "foot" does not make contact, and when we turn it to change its height, it just goes in circles without changing height.
Mar 09, 2010 | Whirlpool Washing Machines
Water comes back in and stands after cycle is run
I'm not sure what washer you have but a lot of washers have an additional spin cycle. If you left the lid open, then it would only fill with water then sit until the lid is closed. Try making sure the lid is closed next time you empty it and see if the water is in there the next morning. I hope this helps. Good luck!
May 25, 2009 | Washing Machines
Duet has no spin cycle... stops at 2 minutes or is 2 an errorcode
I atill don't understand, because my machine it no work at all, when i keed supply power machine nothing work has only red flash light alarm on the spin function?
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Walking Washer
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Apr 25, 2008 | LG WM-2277HW Front Load Washer
Maytag MAV7700, Grinding and water leak
open the front with a puttyknife there are 2 clips about 4" in on each side this wil open the top so you can remove the 2 screws holding the front panel on once removed you can see the guts of the unit..Let me know if you need more help
Jan 28, 2008 | Maytag MAV7600 Top Load Washer
WFMC 3200 WONT SPIN OR WASH
Open machine's rear panel and look for a broken belt and does the motor spins. Let me know with your results and we will see how could we assist you.
Aug 21, 2007 | Bosch WFMC 3200 Front Load Washer
Kenmore 22422 Top Load Washer Logo
44 people viewed this question
Fordexpert
Archaeology
Archaeology
reliableservice
