Akai PX-E855K turntable - switchable pre-amp - how?
I recently found this turntable amongst my daughter's stuff. Still works fine and I would like to use it with my Griffin iMic to copy vinyl to CD. Looking at the 'blurb' I found on the net, it allegedly has a pre-amp which can be switched on or off but how is this done? Or does this not apply to the E855K? I'd like to switch it off as I believe my stand alone pre-amp will be better than the turntable's.
  • rodpaddock Jan 17, 2009
    This of course refers to the AIWA PX-E855K - nothing to do with Akai!!
  • rodpaddock Jan 19, 2009
    Certainly seems to have a pre-amp when I look at the wave form using Audacity compared with my other turntable which certainly doesn't have a pre-amp. I guess the info that it was possible to switch it off was a bum steer. There is no obvious switch. I've decided to use Audacity's 'Effect' options to improve the quality. Many thanks anyway
  • 515 Answers
To my knowledge this is no switchable pre-amp on this unit. Just connect to your own phono pre-amp and you should be ok.
- OPTiC
DJ Equipment Repair Videos
DJ Equipment Repair
DJ Equipment Sales
Pioneer Parts
Posted on Jan 17, 2009
Aiwa turntable not playing through the speakers
Has the amp got a dedicated phono socket for the turntable? If you are using a tape or aux socket it might not have the pre-amp needed to hear the deck. If your amp doesn't have a socket for the deck, you will need a magnetic cartridge pre-amp.
Also check the connections to the cartridge, they might have come loose.
Jun 09, 2014 | Aiwa PX-E860 Turntable
PLEASE CAN YOU TELL ME IF THE AIWA px e10 TURNTABLE HAS A BUILT IN PRE AMP
The Aiwa PX-E860EZ does. I couldn't find anything on the PXE10 though. Plugging it into a tape or aux or CD socket on an amp will soon confirm it. The sound (if it has one) will be normal. If it hasn't it will be very low, but hearable.
Apr 09, 2013 | Aiwa Audio Players & Recorders
Speakers for aiwa PX- E90HE stereo turntable
you also need an amp or reciever, just hooking up speakers to this turntable will not work
Mar 08, 2013 | Audio Players & Recorders
Distorted, cracked sound coming through to the speakers
is it possible your new reciever has a built in phono pre-amp?
If so, you need to switch off the pre-amp inside the turntable (lift up the rubber matt, and rotate the plate untill you see the switch at the back)
Try again now?
Feb 12, 2010 | Aiwa PX-E860 Turntable
We have a SLDD33 turntable and cannot figure out why there is no sound? The auto function no longer works properly but everything else seems fine. It just stopped producing sound one day. Any ideas? If it...
The most obvious cause is a dead cartridge. The other cause is that the turntable is fine, but your amp is not. The reason being that the turntable input on your amp has a pre-amp just for the deck. So you might hear the tape/cd fine, but not the deck. If it is the amp, that's faulty, you can trace the wires from the socket to the PC board. Some amps have this pre-amp on a seperate PC board. You might find a single IC doing the work, my bet is that has gone.
Feb 11, 2010 | Technics SL-BD22 Turntable
Low volume through amp
you will probably need to buy a phono pre amp , i have a Dual 505 turntable that worked fine on my ROTEL amp but when i changed amps and went to NAD i had to buy a phono pre amp or else listen to really low sound . hope this helps
May 23, 2009 | Technics SL-1200MK2 Turntable
Does turntable have a magnetic cartridge?
Styli supplier "me.and.lurch" on eBay informed me that my AIWA turntable already had a pre amp built in.
Apr 10, 2009 | Aiwa PX-E860 Turntable
Humm
where is the ground wire from the turntable connected to ? Ensure that is is connected to the phono pre-amp's ground.
Is the turntable sitting on top/near any other equipment ? Try changing the position and see if the hum reduces. If yes, then it is likely that it is picking up hum from a mains transformer.
Aug 21, 2008 | Aiwa PX-E860 Turntable
Built in Pre-Amp has gone out
Remove the turntable pad (part where the record sits) and the switch is in the corner.
Apr 03, 2008 | Audio Technica AT-PL50 Turntable
307 people viewed this question
 Grubhead
Grubhead
