We have a PC as well as a laptop running on a Linksys router model#BEFW1154 Ver 4 both Windows XP all working fine. We are trying to connect another PC using the wireless B router model#WUSB11 ver 2.8 that is operating on Windows Vista to the router as well & have been unable to establish a connection, any ideas? Can these 2 different Windows run off of the same router?
  • 916 Answers
The 2 different operating systems can run off the same router. Also check to see which type of security you are using I would suggest WPA2 if you do not see that listed you will need a firmware update.
Posted on Jan 15, 2009
My DHCP is not assigning a dynamic address to one of my seven wired devices. I've had to switch over to a stati
On the second router just plug a port cable in from your main routers port into the wan port and then be sure to change the second routers gateway and IP address to a different number. Say that your main router IP is 198.18.1.1 and for your second router IP you could use 10.10.10.1 or what ever combo you want and then you should be able to use both routers together. Is this what you are trying to do?
Linksys routers as well as all routers with DHCP enabled should be able to handle up to 255 separate IP address's for a LAN network. Is the firmware of the Linksys the latest? If not, down load the latest firmware and flash the router to update it. Or, check out third party firmwares like Tomato to flash that tired Linksys and turn it into a real router.
Apr 14, 2017 | Actiontec Verizon Fios Mi424wr Modem...
I am having trouble getting my linksys wrt110 to connect to my laptop windows 7. it works with my xp and vista just fine
you might need to delete the device settings and reconnect to it and select HOME network sometimes that conflicts conections
Mar 02, 2011 | Linksys RangePlus Wireless Router WRT110 -...
Can not access router @ 192.168.1.1 wired or
try to double check you dafault gateway, perform ipconfig to verify. also check if you have static ip on your pc..
Hope it helps!
Feb 14, 2010 | Linksys Wireless-G WRT54G Router
I cant get a wireless connection on my IBM R40 using a Linksys G
I had the same problem with my R40 (2681) and a Linksys G router. The specs on IBM's/Lenovo's site indicate that the wireless card in the R40 only handles certain types of wireless encryption. The newer types (e.g. WPA) won't work on it and they are usually the standard on routers nowadays. My Linksys G router works fine with the R40 with WEP or with no encryption. Not ideal, but that's life with an old laptop.
Dec 14, 2009 | IBM ThinkPad T40 2373 Notebook
Load disk
You can download the software from linksys.com/download. The router can be setup without the software
May 27, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Need wireless connection driver
it should be on your recovery disk that came with computer when it was bought new if you dont have that disk try windows update to fine it
Mar 26, 2009 | IBM Thinkpad T30 Notebook
Linksys Wireless B Router Compatible with Windows Vista?
I would advise you to purchase a Linksys G router, Model # WRT54G2. Works well with Vista and your other laptops will work also.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 26, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
My linksys router won't allow me to connect to the internet.
You probley should get a new one. The new ones should have a better conecsion and more settings.
Jan 08, 2009 | Linksys Wireless-G WRT54G Router
Can you tell me if a Linksys Router will work with Windows 2000(Millenium) - XP or Vista. I have a Linksys Router Model # WRT54G. My friend also has a Linksys Router (I dont know model # of that one. He is...
This should work fine. Report here with the specific problem that are being encountered and we should be able to determine whether or not the actual hardware has a problem.
Dan
Mar 19, 2008 | Computers & Internet
Drivers 4 Linksys BEFW11S4 ver. 4
Your wired network adapter will talk to a wired router without a driver for the router on your computer. Your wireless adapter likewise will talk to your wireless router without a driver for the wireless router on your computer. Your wired and wireless adapters however do require drivers and the wireless adapter can require configuration. Please provide the manufacturer and model of your computer so I can learn about your wireless adapter and we can work to get it connected to the router.
Do you currently have your router connected to your internet service providers connection and do you have another wired or wireless computer successfully using this device to access the internet?
Dec 09, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
